Hi guys,
Long story short, I came to the conclusion that the guy who sold me my system didn't treat it well because when I got it I had to reapply thermal paste since it was completely dry so the CPU was running full tilt at 90°c on the bios screen, lol.
Anyway, is it possible that this killed the CPU?
I bought a used i5 4440 and it runs no problem on the system, but when I try to boot with the "old" one (so the 4460s), the machine boots but there's no signal output and the peripherals do not light up.
Any ideas?
https://linustechtips.com/topic/820061-cpu-going-insane/
I wonder if the guy before you also had it running full tilt all the time at 90c and just never gave a fuck, that probably would have screwed it up
Current: R2600X@4.0GHz\\ Corsair Air 280x \\ RTX 2070 \\ 16GB DDR3 2666 \\ 1KW EVGA Supernova\\ Asus B450 TUF
Old Systems: A6 5200 APU -- A10 7800K + HD6670 -- FX 9370 + 2X R9 290 -- G3258 + R9 280 -- 4690K + RX480
https://linustechtips.com/topic/820061-cpu-going-insane/#findComment-10278077
He told me he never opened the system but to put a graphics card in it. It was also very dusty
https://linustechtips.com/topic/820061-cpu-going-insane/#findComment-10278081
