ASAP help!!! window 10 driver auto update
- install window 10, automatically install broken GPU driver! > crash
- use Wushowhide.diagcab a tool to block specific driver can't find it since it's the first and number one driver window install
- internet : off Wushowhide can't detect driver to hide
- internet : on window update faster than Wushowhide , installing GPU driver is already on queue!
- DDU can delete driver completely but need restart
- imagine the loop install driver > bluescreen > launch fix > safe mode > remove driver > try to block driver > window is faster > bluescreen
- taking off GPU is not an option
best solution?
https://linustechtips.com/topic/819678-asap-help-window-10-driver-auto-update/
best solution?
Download a driver that works.
put it on a USB drive
unplug pc from the webs
run ddu - it has an option to disable auto updates on hardware or something like that. Use it.
after DDU has done its job stay in safe mode and install your driver from usbUSB
or try a clean install of windows without being connected to the internet
NO DRIVER IS WORK
a dead gpu mean you can't never use that gpu or else it will kill the system
installing a driver for the gpu mean using it!
i have 1 computer to work with
i have onbroad intel intergrade hd3000 which i am using
and a dedicate literally glue to hold the gpu on place cause old design laptop, so peel off the gpu is not an option
Another way could be to plug the monitor into the motherboard instead of the GPU.  Remove the GPU and then run DDU and update driver.  After it is installed add GPU and it should work.  I accidentally backdated my driver so my GPU wouldn't work and I repaired it this way.
Think op might be using  a laptop. NoT that it Is mentioned in OP
7 minutes ago, dafo446 said:
NO DRIVER IS WORK
Disable the gpu in device manager. Try your bios if it has similar options.
ok another question i have now disable.... more like pause the gpu update at mid way through disable firewall
the progress is at 50% so... how can i delete that cache? that progress?
Well An incomplete download shouldn't do anything.
I assume its windows update that you blocked?
so it's the update install files you want to delete. You can do this by running a disk clean. Just type it in th search field. Or google how to delete them Manually. Afraid I don't remember the location
