Ryzen 7 CPU led on
Go to solution Solved by Zyndo,
5 minutes ago, shakerhobgoblin said:
Snip
You should (in no particular order)
Check that you have at least one of your fans connected to your CPU COOLER header
Reseat your CPU.
Check all power cable connections and be sure to reseat all of those. ensure your 8 pin EPS connector, 24 pin ATX connector, and appropriate PCIe power connectors are all attached (and even if they appear to be, unplug them and re-connect them anyway).
Clear your CMOS. In very rare cases a motherboard can sometimes come without the natural stock settings applied (especially if its a refurb), which could manifest as a boot issue.
Hey I built my first PC and when it didn't post i notice this red led so i checked the mobo manual and its the led light for the CPU so i double checked i installed it right double checked all cables and standoffs and still didn't work then tried with single dimm in all 4 lots am i missing anything or is my CPU DOA.
also all case fans work and the CPU fan works and the psu works fine and the GPU lights up and appears to work
im running
ryzen 7 1700
stock cooler
gigabyte  ax370 k3
g-skill rip-jaws 16gb kit
intel 600p 512gb ssd
2tb barracuda
evga sc2 1080ti
evga g2 750w psu
https://linustechtips.com/topic/819519-ryzen-7-cpu-led-on/
Snip
Reseat your CPU.
https://linustechtips.com/topic/819519-ryzen-7-cpu-led-on/#findComment-10271622
Reseat your CPU.
There is a clear cmos thing on thr mobo aswell as the battery does it matter which method i choose to use?
https://linustechtips.com/topic/819519-ryzen-7-cpu-led-on/#findComment-10271627
