Hello, I came home from a holiday a month ago and my computer wouldn't start.
When I hit the power button all the fans turns on, and after 30 seconds it turns off.
So my first thought was a failed psu, so I switched it out. Still no post.
After that I thought it gotta be the MB, so I switched that out aswell. And it still doesn't work.
I've tried switching the CMO battery, all the cables, tried with one ram and reassemble it.
The Q-codes indicates that it should be starting.
I've also tested if it's the monitor.
So in my head it gotta be either the RAM or the CPU.
I can send a video of it starting if necessary.
My specs:
CPU: I7 5820k
Old MB: x99 strix
New MB: x99 sabertooth
Old PSU: EVGA supernova 750w g2
New PSU: EVGA supernova 750w g3
RAM: Crucial 4x4gb 3200mhz
Hope sincerely someone can help me.
- Carl
https://linustechtips.com/topic/818824-computer-wont-post-after-vacation/
Any post codes?
Current LTT F@H Rank: 24    Score: 10,097,484,643   Stats
Yes, I have 9 monitors.
My main PC:
OS: Windows 11
CPU: Ryzen 9 9950X
Cooler: Noctua NH-D15
Mobo: Asus ProArt X670E Creator WiFi
RAM: 96GB Trident Z Neo @6400 CL32
GPU: RTX 4090 Founders Edition, Radeon Pro WX 5100
PSU: Corsair RM1000e
SSDs: Samsung 990 Pro 4TB NVME, Samsung 970 evo plus 1TB NVME, 2x Samsung 870 evo 2TB, Samsung 860 evo 1TB, Samsung 970 evo 500GB NVME
Case: Fractal Design Define R5 Black w/ Tempered Glass Side Panel Upgrade
Monitors: 9 Monitors: Alienware AW3423DWF 3440x1440@165Hz, Acer H236HLbid 1080p@77Hz, HP D7z72AA 1080p@60Hz, Dell Inspiron 24 3459 1080p@60Hz(used only as display), Dell U2724D 1440p@120Hz, ASUS VP228 1080p@60Hz, 2x HP ZR2440W 1200p@60Hz
unRAID server (Plex, Backups, NAS, Duplicati, game servers):
OS: unRAID 7.1.4
CPU: Ryzen R9 3900X
Cooler: Noctua NH-U9S
Mobo: Asus ROG Strix X470-F
RAM: 64GB G-Skill Ripjaws V @ 3200MHz
PSU: EVGA G3 850W
Total Storage: Raw: 94TB, Usable: 64TB
SSD: Samsung 990 Pro 2TB NVME, Teamgroup 4TB NVME
HDDs: 4x HGST Dekstar NAS 4TB @ 7200RPM (3 data, 1 parity) + (7x Seagate Ironwolf NAS 8TB + 2x Toshiba N300 NAS 8TB in ZFS)
Case: Fractal Define 7 XL
Other: Added 3x Noctua NF-F12 intake, 2x Noctua NF-A8 exhaust, Inatek 5 port USB 3.0 expansion card with usb 3.0 front panel header
47 minutes ago, Biggerboot said:
No splash screen at all?  Just want to confirm that's what you're seeing.
Also make sure the motherboard isn't shorting (it's installed correctly on standoffs, or you could test it out of the case).
Nothing is displayed on the monitor. It is all black.
Does your board have a diagnostic speaker?  Try the one stick of RAM again and see if you get any beeps.  Try every single stick in different slots.
