Good case fans for aura sync?
Solved by W-L,
Just now, MoBassaid said:What are some good caservice fans for aura sync ? Don't really want to spend above £60
I have a nzxt s340 elite if that helps
To sync it with the motherboard your options are limited, there is currently the coolermaster RGB fans and Akasa Vega fans which can interface all together.
Featured Topics
Bloodybluedragon ·
Posted in New Builds and Planning2 -
3
AlexGoesHigh ·
Posted in Linux, macOS and Everything Not-Windows3 -
rlaphoenix ·
Posted in Displays0 -
ulookuglynoob ·
Posted in Mobile Gaming2 -
I eat limes often ·
Posted in Laptops and Pre-Built Systems3 -
1
