- I want to find a Rechargeable wireless mouse with the budget: don't be unreasonable
- Have 2 wireless mode Bluetooth connection and "Dongle" connection (have a dongle slot in the mouse bottom so it can store the dongle itself!)
- Can use wire mode if you connect the USB wire.
- If best come with rechargeable AA removable battery.
- have Good sensor can track fast movement for competitive gaming (well this is 2017 a 40$ mouse can ez have those kinds of sensor) , and good clicking durability.
- have at least 2 Side button, with a software to work with!
- Lazer or Optical i don't care
any to recommend? or i asking too much? (this isn't too much!)
Logitech MX master mouse. It's literally the nicest wireless mouse I've tested.
I suck a typing, preparw for typos.
Desktop
CPU: Ryzen 7 3700x MOBO: MSI X570-A Pro RAM: 32 GB Corsair DDR4
GPUS: Gigabyte GTX 1660ti OC 6G  CASE: Corsair Carbide 100R STORAGE: Samsung Evo 960 500GB, Crucial P1 M.2 NVME 1TB   PSU: Corsair CX550M CPU COOLER: Corsair H100x
LAPTOP
Apple Macbook Pro 13 M1 Pro
So you want a competitive grade wireless mouse for $40? Doesn't exist. In 2017 your options are pretty much the G900 or G403 Wireless (Or their revised versions G903 and G703). Although I am a bit of a mouse purest in that I would not want to use a laser sensor for competitive gaming, and the lighter the mouse the better. Although most of this is only really necessary if you play competitive FPS, as you don't need the same kind of mouse precision in other genres. So in that case you should just get any logitech wireless mouse.
Processor: Ryzen 5950x GPU: RTX 3080  Mobo: X570 Aorus Pro RAM: 32GB DDR4 3200Mhz CPU Cooler: Noctua NH-D15
For officey kind of stuff, the logitech MX anywhere/master lineup is good. However they have a bit of acceleration, and the clicks wear out after a couple of years of regular use. If you want a decent mouse on a budget, go wired, as decent wireless gaming mice don't come cheap. If you are willing to spend the $$$ then the Logitech ones are good.
Sync RGB fans with motherboard RGB header.
Main rig:
Ryzen 7 1700x (4.05GHz)
EVGA GTX 1070 FTW ACX 3.0
16GB G. Skill Flare X 3466MHz CL14
Crosshair VI Hero
EK Supremacy Evo
EVGA SuperNova 850 G2
Intel 540s 240GB, Intel 520 240GB + WD Black 500GB
Corsair Crystal Series 460x
Asus Strix Soar
Laptop:
Dell E6430s
i7-3520M + On board GPU
16GB 1600MHz DDR3.
