1 minute ago, xXBlackIceXx said:
Ive tried. Im only 15 just trying to get into px gaming
its easy, I was 16 and already had a good knowledge on pretty much building pc's.
now honestly I've never noticed a difference between 60hz and 120hz  even though I have a monitor that can do 144hz.
wasn't a thing for me. and because I went on the cheap and got a budget 144hz it was riddled with color problems and everything, absolute nightmare. fixed it and its decenet though. a decent 60hz should do fine honestly and you can save money and spend money on better parts.
https://linustechtips.com/topic/818592-help-me/#findComment-10261389
CPU: AMD - Ryzen 5 1600 3.2GHz 6-Core Processor  ($264.99 @ Amazon Canada)
Motherboard: Asus - STRIX B350-F GAMING ATX AM4 Motherboard  ($132.99 @ Newegg Canada)
Memory: Team - Vulcan 16GB (2 x 8GB) DDR4-3000 Memory  ($149.99 @ Newegg Canada)
Storage: Crucial - MX300 275GB 2.5" Solid State Drive  ($123.99 @ PC Canada)
Storage: Seagate - BarraCuda 1TB 3.5" 7200RPM Internal Hard Drive  ($54.75 @ shopRBC)
Video Card: Asus - GeForce GTX 1070 8GB Dual Series Video Card  ($549.99 @ Newegg Canada)
Case: Phanteks - ECLIPSE P400S TEMPERED GLASS ATX Mid Tower Case  ($114.99 @ Newegg Canada)
Power Supply: EVGA - B3 450W 80+ Bronze Certified Fully-Modular ATX Power Supply  ($64.99 @ Newegg Canada)
Monitor: QNIX - Perfect Pixel QX2710 Matte 27.0" 2560x1440 60Hz Monitor  ($389.99 @ Newegg Canada Marketplace)
Keyboard: Rosewill - RK-9000V2 Wired Standard Keyboard  ($89.99 @ Amazon Canada)
Mouse: Corsair - Harpoon RGB Wired Optical Mouse  ($46.77 @ DirectCanada)
Total: $1983.43
Nice mech keyboard, nice RGB mouse, nice case. I included a nice 1440p monitor. Most people with a QX2710 have been able to OC between 96-120Hz easily. GTX 1070 is fine for 1440p60, and will be alright for 1440p beyond 60Hz if you overclock the monitor. A GTX 1080 would be better, but not going to fit within this budget unless you drop down to an entry level 1440p monitor that likely won't OC as well as the QX2710.
Intel Core i7-4790k @ 4.7GHz | Asus Maximus VII Hero | NZXT Kraken X61 | 2x8GB Corsair Vengeance Pro(Red) @ 1866MHz | 2TB Seagate Barracuda | 250GB Samsung 850-EVO | 2- way SLI Asus Strix GTX 970's @ 1500MHz | EVGA 750W G2 | NZXT H440(black/red) | 3x120mm Sharkoon Shark Blade fans(red) | 3x140mm Be Quiet! Pure Wings 2 fans |
https://linustechtips.com/topic/818592-help-me/#findComment-10261475
