is my memory running at the right speed?
Go to solution Solved by LienusLateTips,
Yeah, it's right.
So I have 32gb (4x8) g.skill TridentZ 3000, and I know it's set to 3000 mhz in the bios. However when I look at cpu-z it shows up as DDR4-2132 (1066 Mhz): http://i.imgur.com/3wXBWE6.png
However it ALSO says that my XMP frequency is 1500Mhz (which i assume results in 3000 Mhz once you take dual channel into account?). ASUS Suite III confirms a 3000 Mhz speed, but I just want to be sure.
Yeah, it's right.
Full Specs
Helios EVO (Main):
Pacific Spirit XT - Server
Delta - Laptop
DDR = double data rate
Hence 1500MHz after double data rate equals to 3000MHz.
CPU-Z will always show the default clocks for the DDR standard, so in this case it would be 1066MHz for DDR4.
Frost | 7700K @ 4.9GHz 1.36v, delidded | Asus DUAL GTX 1060 6GB OC | Corsair LPX 16GB DDR4 2800MHz | Samsung 960 EVO 250GB SSD + Toshiba 1TB HDD + Toshiba 2TB HDD + Samsung 860 EVO 1TB SSD for macOS | Asus PRIME Z270-A | Fractal Design Celsius S24 | Seasonic M12-II 620W PSU | Corsair 400C White | NZXT Hue+
Samsung Galaxy S8 | Stock
Ticwatch E (Black) | Ticwatch Brown Leather Strap
Yes, you double it, but not because of you running "dual channel". You double it because of it being DDR4 memory.
DDR = Double Data Rate (DDR4 = Gen 4).
