Hey guys, I have a really crappy PSU that makes a lot of noise. Now, I'm getting two new 120mm case fans for my DeepCool Gammaxx 400 and I'll be using its current fan to replace the PSU fan. I'm getting the fans from https://www.aria.co.uk/, which ones should I get? I was thinking about the Arctic 120mm PWM, but then I saw the BeQuiet Pure Wings 2, which ones should I go with? The Arctic fans have better airflow than the BeQuiet and also cheaper. Also, can I power two CPU fans out of the same CPU_fan header on my motherboard?
Many thanks, Bruno.
Quote me so I can reply back :)
MY PC-> PSU: EVGA SuperNOVA T2 1000W 80 Plus Titanium MOTHERBOARD: ASUS X370 Crosshair VI Hero CPU: RYZEN 7 3700X RAM: G.Skill 32GB (4X8GB) DDR4 3200MHz C14 GPU: EVGA GTX 1080Ti FTW3 HYBRID STORAGE: Samsung 970 EVO 500GB NVMe SSD; 2TB WD Caviar Blue; Crucial MX500 500GB SSD CUSTOM LOOP: EK-Velocity Nickel + Plexi CPU block, EK-FC1080 GTX Ti Acetal + Nickel GPU Block w/ EK-FC1080 GTX Ti Backplate, EK-XRES 140 Revo D5 PWM, EK-CoolStream PE 240 w/ 2x Noctua NF-F12 Chromax fans, EK-ACF Fitting 10/13mm Nickel, Mayhems UV White tubing 13/10mm, 3x Noctua NF-S12A Chromax case fans
https://linustechtips.com/topic/818464-cpu-fans/
7 minutes ago, Maxxtraxx said:
My personal opinion, Corsair ML120 Pro, quiet, excellent lighting style... it's a maglev fan for crying out loud.
Here
Yes, you can power 2 fans from 1 header with a fan header splitter.
Link to not the best example: here
£18 would be my max budget for the 2 fans xD As for the fan header, I know I can use a splitter, but, would that be safe? As far as I know, fan headers can only draw so much.
https://linustechtips.com/topic/818464-cpu-fans/#findComment-10260119
