Yo!
So, I'll be moving to a different country soon.
For this, I'll dismantle my PC and bring the parts, then get a new case over there.
I'm planning out my desk setup and I want to get a white PC case.
Now, there's a few caveats.
My motherboard is EATX, which limits my case selection a bit.
Also, I plan on swapping it out later because I'm running Intel right now, and I have a GTX970.
I've been itching to go back to the red team and this seems to be the perfect time to do it.
BUT, I want to do a fully white build and apparently there's no white motherboards for the TR4 socket yet (If I'm gonna swap to AMD I want to get the very best they have, it'll be useful for my 4k video editing).
Also, even among the white cases, most are still black inside, which is a no-no!
So I guess it'll be a step by step white build. First I'm moving my current components inside a white case, and then I'll slowly swap out the internals for white stuff.
I guess one route I could go is get black stuff with RGB lighting, but this will create more of a black/white theme. I'm trying to go fully white!
Any suggestions?
I am one with the Force, and the Force is with me.
https://linustechtips.com/topic/818269-help-with-white-build/
Just buy the case and spray the remaining black parts white, I did it with in win 303. In fact I sprayed pretty much everything white. As for x399, msi must have an arctic or tomahawk in the pipeline
Ryzen Ram Guide
My Project Logs   Iced Blood    Temporal Snow    Temporal Snow Ryzen Refresh
CPU - Ryzen 1700 @ 4Ghz  Motherboard - Gigabyte AX370 Aorus Gaming 5   Ram - 16Gb GSkill Trident Z RGB 3200  GPU - Palit 1080GTX Gamerock Premium  Storage - Samsung XP941 256GB, Crucial MX300 525GB, Seagate Barracuda 1TB   PSU - Fractal Design Newton R3 1000W  Case - INWIN 303 White Display - Asus PG278Q Gsync 144hz 1440P
https://linustechtips.com/topic/818269-help-with-white-build/#findComment-10258082
I looked at these two series for ryzen 7 and there's one issue: I need 10 gigabit LAN. Neither of them had it... Not to mention they're not TR4.
Then I found the AORUS which has RGB all over. Also no 10GBit LAN.
Finally, looked at the ASUS ROG ZENITH EXTREME which does have 10GBit LAN but that's black, albeit RGB.
Do we know if the TR4 MSI boards are getting 10GBit LAN?
https://linustechtips.com/topic/818269-help-with-white-build/#findComment-10258106
Why not an addon card for 10Gbit?
You're going to have a very hard time finding non-server parts with 10Gb LAN.
I know Asus (I think it was them) came out with a 10Gbit copper addon card for $100
Current Network Layout:
Current Build Log/PC:
Storage Server Setup:
Prior Build Log/PC:
https://linustechtips.com/topic/818269-help-with-white-build/#findComment-10258111
The white Noctis 450 and H440 have white interiors.
MSI makes a lot of white boards, so does ASRrock if they make a TR4 Pro4
-----> Official Unofficial Favorite Keyswitch Type Survey <-----
 OWNER OF THE FASTEST INTEL iGPU ON LTT UNIGINE SUPERPOSITION [lol]
GAMING RIG "SNOWBLIND"
CPU i5-13600k | COOLING Corsair H150i Elite Capellix 360mm (White) | MOTHERBOARD Gigabyte Z690 Aero G DDR4 | GPU Gigabyte RTX 3070 Vision OC (White) | RAM  16GB Corsair Vengeance Pro RGB (White)SSD Samsung 980 Pro 1TB | PSU ASUS STRIX 850W (White)CASE  Phanteks G360a (White) | HEADPHONES  Beyerdynamic DT990 Pro | KEYBOARD Zoom75 (KTT Strawberry w/ GMK British Racing Green keycaps) | MOUSE  Cooler Master MM711 (White) MONITOR HP X32 1440p 165hz IPS
WORK RIG "OVERPRICED BRICK"
Mac Studio (M2 Ultra / 128GB / 1TB) | HEADPHONES  AirPods Pro 2 | KEYBOARD Logitech MX Mechanical Mini | MOUSE  Logitech MX Master 3S MONITOR 2x Dell 4K 32"
SECONDARY RIG "ALCATRAZ"
CPU i7-4770K OC @ 4.3GHz | COOLING Cryorig M9i (review| MOTHERBOARD ASUS Z87-PROGPU Gigabyte 1650 Super Windforce OC | RAM  16GB Crucial Ballistix Sport DDR3 1600 MHzSSD Samsung 860 Evo 512GB | HDD Toshiba 3TB 7200RPMPSU EVGA SuperNOVA NEX 750WCASE  NZXT H230 | HEADPHONES  Sony WH-1000XM3  | KEYBOARD Corsair STRAFE - Cherry MX Brown | MOUSE  Logitech G602 MONITOR LG 34UM58-P 34" Ultrawide
HOLA NIGHT THEMERS
GET YOUR ASS ON NIGHT THEME
OTHER TECH I OWN:
MacBook Pro 16" [M1 Pro/32GB/1TB] | 2022 Volkswagen GTI | iPhone 14 Pro | Sony a6000 | Apple Watch Series 8 45mm | 2018 MBP 15" | Lenovo Flex 3 [i7-5500U, HD5500 (fastest on the forum), 8GB RAM, 256GB Samsung 840 Evo] | PS5, Xbox One & Nintendo Switch [Home Theater setup] | DJI Phantom 3 Standard | AirPods 2 | Jaybird Freedom (two pairs) & X2 [long story, PM if you want to know why I have 3 pairs of Jaybirds]
https://linustechtips.com/topic/818269-help-with-white-build/#findComment-10258113
Hmmm I guess an addon card is a good idea, BUT I'd like to get it in the Motherboard if I can because I feel like the high price we'll pay for X399 should warrant that. Although, an addon card like that shouldn't be too expensive, right?
https://linustechtips.com/topic/818269-help-with-white-build/#findComment-10258119
Yeah I think I'm sold on the H440. Colorware has skins for it which I might do... Hmmm thanks!
But wait, does it fit an EATX board in it?
https://linustechtips.com/topic/818269-help-with-white-build/#findComment-10258123
Judging by your component selection you're not afraid of having a healthy budget, so I'll suggest my two favorite ATX cases:
  • Thermaltake Tower 900
  • Caselabs Bullet 7/8
Honorable mentions:
  • Caselabs Mercury S8
  • Phanteks P400S TG
MiniPC - Sold for $100 Profit
OG Gaming Rig - Gone
https://linustechtips.com/topic/818269-help-with-white-build/#findComment-10258130
Was also thinking asus may do a x399 deluxe just might not be able to go threadripped on release
alternatively just get which ever board you like and use a monoblock on water like i did with my ryzen build
Ryzen Ram Guide
https://linustechtips.com/topic/818269-help-with-white-build/#findComment-10258182
Please elaborate. Monoblock on water!?
https://linustechtips.com/topic/818269-help-with-white-build/#findComment-10258212
Honorable mentions:
  • Phanteks P400S TG
All aluminum case eh? I LIKE IT.
The tower one, I really like the fishtank look, but for it to have the look I want, I'd need ALL components to be white... I'm not sure that's possible (I'm guessing we will see a LOT of new hardware being released in time for the holidays so this problem might go away.... what do you think?)
https://linustechtips.com/topic/818269-help-with-white-build/#findComment-10258225
53 minutes ago, GM Rod said:
Also, how about white liquid coolers?
I've been able to find air coolers in white, but not liquid AIOs...
You guys know any?
Deepcool Captain 240 EX White is one of the few I know of
Prior Build Log/PC:
https://linustechtips.com/topic/818269-help-with-white-build/#findComment-10258398
1 minute ago, GM Rod said:
Hmmm.
Black tubes, black fans. Not quite there yet... Dang this is hard.
Not sure if or how well these would work:
https://cablemod.com/product/cablemod-aio-sleeving-kit-series-2-for-evga-clc-nzxt-kraken-white/
Another, cheaper, option is white tape.
Fans can be replaced pretty easily :)
Prior Build Log/PC:
https://linustechtips.com/topic/818269-help-with-white-build/#findComment-10258417
AH HA!
Cablemod to the rescue!!!
Thank you.
https://linustechtips.com/topic/818269-help-with-white-build/#findComment-10258420
AH HA!
Thank you.
Just be careful though, it doesn't list the Deepcool in the compatible list so you might have to tweak it or something :)
Prior Build Log/PC:
https://linustechtips.com/topic/818269-help-with-white-build/#findComment-10258427
I have a custom water loop
And I split the monoblock apart and applied white vinyl around the outer edges to keep it in the white theme
Ryzen Ram Guide
https://linustechtips.com/topic/818269-help-with-white-build/#findComment-10258590
@stealth80
THAT IS FUCKING SEXY
OP do that
HOLA NIGHT THEMERS
OTHER TECH I OWN:
https://linustechtips.com/topic/818269-help-with-white-build/#findComment-10259100
But I've never done a custom water loop, Hmmm
always a first time!
HOLA NIGHT THEMERS
OTHER TECH I OWN:
https://linustechtips.com/topic/818269-help-with-white-build/#findComment-10260387
@GM Rod @Lurick we didn't test these on Deepcool so you would want to only follow coolers listed as supported to ensure it would properly fit. We also offer a version for compatible Corsair AIO's as well. You can find these at a variety of resellers already, with these coming to other resellers very soon if not already available.
https://store.cablemod.com/product/cablemod-aio-sleeving-kit-series-1-for-corsair-hydro-gen-2/
https://linustechtips.com/topic/818269-help-with-white-build/#findComment-10260928
It looks like I'm gonna go full custom loop so that's no longer an issue, but the attention is much appreciated!!!
I'm still getting cablemod stuff for power though :-)
https://linustechtips.com/topic/818269-help-with-white-build/#findComment-10260963
Ok so, since it's my first custom loop, I should start with soft tubing, right.
And, if I get the Vega RX 64, do I get the air one to save $ then remove the shroud and install the EK block?
Or do I get the water cooled one and just take the AIO out and plug in the EK tubes instead?
https://linustechtips.com/topic/818269-help-with-white-build/#findComment-10260966
So wait, you painted the reservoir right?
I'm at the EK site and all the ones I see are black.
https://linustechtips.com/topic/818269-help-with-white-build/#findComment-10261000
