Building gaming server and need hardware help.
Solved by RadiatingLight,
23 minutes ago, Taco Squad said:I would like to stick with duel core CPU's because the machine will be mostly played with minecraft servers which can only use 1 core from what I read. What would be the best $100 and under CPU or at least a few to look at?
well, if you're only running no more than 2 servers, the best would be the highest number i3 you can find.
the 7100 would be a good choice. (if you are only using 2 cores - AKA 2 servers.)
AFAIK they can use more, but you probably know more than I do.
