2 minutes ago, Chowdr71 said:
https://pcpartpicker.com/user/TBufalino/saved/36HZLk Help a noob out this is my first build I am going for a content creation with gaming in addition to being used to complete my computer science degree. Budget is no more than $6500USD.
Looks fine to me, although a DVD drive?
Have you tried turning it off and on again?
5 minutes ago, Chowdr71 said:
I use a program called Dragon Naturally Speaking that is on my laptop but it is a disc based program to write documents or really any typing, in fact, I'm speaking this response
ah right ok, I would consider getting a cheaper drive if money was an issue, which it doesn't appear to be.
If your focus is also on content creation, I'd be looking at the R7 1700 instead.
Do you also need three 1440p 144Hz G-Sync monitors? I'd just get one and have either some 4K monitors or basic 1440p monitors for productivity.
'Fanboyism is stupid' - someone on this forum.
Be nice to each other boys and girls. And don't cheap out on a power supply.
CPU: Intel Core i7 4790K - 4.5 GHz | Motherboard: ASUS MAXIMUS VII HERO | RAM: 32GB Corsair Vengeance Pro DDR3 | SSD: Samsung 850 EVO - 500GB | GPU: MSI GTX 980 Ti Gaming 6GB | PSU: EVGA SuperNOVA 650 G2 | Case: NZXT Phantom 530 | Cooling: CRYORIG R1 Ultimate | Monitor: ASUS ROG Swift PG279Q | Peripherals: Corsair Vengeance K70 and Razer DeathAdder
In the research I have done it was heavily suggested that with surround its best to stick with the same monitor. The gsync was a happy accident my only requirement was a high refresh rate and IPS it appeared 1440p was my best option. if you have some other suggestions I am open to them.
will 2 2160 and one 1440 be an issue compatibility wise?
If you're only gaming on one monitor (aka the Acer XB271HU), it won't be an issue if you have different monitors for other work. Triple monitor gaming is a different matter altogether. Besides, I imagine having a higher resolution monitor would be more favourable for your content creation work.
No, you shouldn't run into any issues.
I did want to at least try triple monitor gaming
Then I'd stick with the three XB271HUs.
