Hey!
I am looking for a portable pc case. I do have a few requirements though and I shall list them.
Needs space for a watercooled CPU (240mm likely)
Space for watercooled GPU (120mm)
2 x 3.5" HDD bays
1x 2.5" SSD Bay
Beyond that, it doesn't matter to much. Looks aren't *that* important to me.
This build will incorporate a Ryzen 7 CPU (1700 or 1700X) and a EVGA GTX 1080 TI Hybrid. Thanks!
https://linustechtips.com/topic/817516-looking-for-portable-case/
1 minute ago, MrLawlessGaming said:
-op snip-
Motherboard size?
Hoping mini ITX but could go matx or atx
Wish I could recommend the Corsair 380T but it's been discontinued :(
You could look at the Fractal Design Define Nano S
Bitfenix prodigy, watercooling can be a bit tough, but has been done in it before. It has handles too.
CPU: Intel Core I7 7700K & Corsair H100i v2
Mobo: Asus Maximus IX Hero
RAM: 32 Gigs @ 3000Mhz, Corsair Dominator Platinum
GPU: Asus Strix 1080 A8G
Storage: Samsung 840 EVO 500gb
PSU: Corsair HX750i
Case: Fractal Design Define S
Just now, Himommies said:
Manta's airflow is better simply because it has more open space and it's like a 20 dollar diffrence
yes but your trading a psu basement for a smaller motherboard size, and its bigger also OP is looking for something portable
PPCS has a watercooled version
http://www.performance-pcs.com/bitfenix-prodigy-mk-ii-mini-itx-case-custom-hardlined-edition.html
My life
The manta has a basement and watercooling will be easier
They are about the same size
My life
2 minutes ago, Himommies said:
Sorry again. Another oversight on my part. I am using AIO cooling solutions. I have a 1080 TI hybrid as is and will probably just use a corsair or what have you for CPU
What is your budget? If budget is not a question, you might wanna take a look at a case labs solution: http://www.caselabs-store.com/bullet-bh2-mitx-case-customizable/
PSU: Corsair HX750i
170 that's pretty cheap for a case considering Freeform stuff has almost bankrupted me
My life
I have suggested lian-li cases in the past, some people like them, some people dont. If I had to pick a portable case it would be the TU300
Core i7 7700k Kabylake stock + Kraken x52 | ASUS Z170-A | 8GB DDR4 2133MHz HyperX | ASUS GeForce GTX 1060 STRIX 6GB | 250GB SSD Samsung 850 EVO + 2TB HDD WD RE4 | Seasonic X-Series 650w | Corsair 460x RGB  | Win 10 Pro 64 bit | Corsair M65 PRO RGB Mouse | Corsair K70 RGB RapidFire
