RAM Problem
Solved by Bananasplit_00,
15 hours ago, rjotto said:Is it possible to do something else to pinpoint the problem more precisely? Are there any diagnostic tools that will show if the cpu's memory controller is the problem?
no there are no such tools. there is only testing you can do. if you swap the CPU and the chanels are still dead, the motherboard is to blame, if you swap the CPU into another motherboard and the chanel is still dead the IMC is to blame
