Hello! i just wanna upgrade my pc and i don't know what psu to buy, i spotted one but don't really know if it is good. Please help!
Specs:
Mobo: asus p8h61 -m lx3 r2.0
CPU: i3 2120 (2cores 4threads 3.3ghz)
GPU: MSI GTX 960 (2gigs,  btw i found it for 95$)
Ram: 6gigs 1333mhz
                                       AND
i wanna buy Deep Cool DN400 PSU (400watts)
So is it any good? Please help and thanks for reading :)
https://linustechtips.com/topic/817373-good-psu-please-help/
1 minute ago, TheR4vas said:
I would take a 650w atleast for future upgrades.
That wattage might be a bit overkill for that hardware combo, I go with a 500w unit instead, might be cheaper
Specs:
Ram: 6gigs 1333mhz
                                       AND
That power supply should be quite OK, I also do recommend the 500BQ from EVGA (https://www.evga.com/products/product.aspx?pn=110-BQ-0500-K1)if you need more power head room.
P/S: You can read some reviews from JonnyGURU (http://www.jonnyguru.com) if you need some expert opinions on power supply, he makes some of the best reviews on power supply.
https://linustechtips.com/topic/817373-good-psu-please-help/#findComment-10249675
This is an excellent cheap option. If you want to get a better one for even further in the future, or aim to get something better than an i5/gtx 1070-like rig, I'd probably recommend something like this (although there are quite a few good options in the $80-100 range).
Previously Trogdor8freebird
5800x | Asus x570 Pro Wifi (barely enough for 64GB apparently given it's 2133 and still crashes sometimes) | 64GB DDR4 | 3070 Ti 8GB | Love that whole weeb shit
https://linustechtips.com/topic/817373-good-psu-please-help/#findComment-10249690
Thanks!!!
https://linustechtips.com/topic/817373-good-psu-please-help/#findComment-10249694
2 minutes ago, _SAITAMA_ said:
Thanks!!!
np :)
https://linustechtips.com/topic/817373-good-psu-please-help/#findComment-10249703
Specs:
Ram: 6gigs 1333mhz
                                       AND
which country are you at? neither the BQ or B1 are very good quality. look for a CX450/550M or Seasonic S/M12ii(albeit old) instead.
https://linustechtips.com/topic/817373-good-psu-please-help/#findComment-10249817
Specs:
Ram: 6gigs 1333mhz
                                       AND
Probably not. Get something like EVGA B3, Corsair CX-M grey, Seasonic S12II/M12II-EVO
Desktop specs:
AMD Ryzen 5 5600 Thermalright Peerless Assassin 120 SE ARGB Gigabyte B550M DS3H mATX
Asrock Challenger Pro OC Radeon RX 6700 XT Corsair Vengeance LPX 16GB (8Gx2) 3600MHz CL18 Kingston NV2 1TB PCIe 4.0 NVMe SSD
Montech Century 850W Gold Tecware Nexus Air (Black) ATX Mid Tower
Laptop: Lenovo Ideapad 5 Pro 16ACH6
Phone: Xiaomi Redmi Note 10 Pro 8+128
https://linustechtips.com/topic/817373-good-psu-please-help/#findComment-10253340
deleted
Edited by ZM Fong
Desktop specs:
https://linustechtips.com/topic/817373-good-psu-please-help/#findComment-10253341
wich would be Skylake-X and a Titan, wich seems highly unlikely...
For a normal mid range system and future upgrades, 650W is just bullshit because you might need half of it - if you're lucky.
Sometimes not even that.
Even with my i7-3930K + RX480 (Power Color Red Devil) I'm normally at around 300W (+/- 50W) on my Powerconsumptionguessing Device...
And it's safe to assume that mid range Hardware will not consume more powe rin the future...
"Hell is full of good meanings, but Heaven is full of good works"
https://linustechtips.com/topic/817373-good-psu-please-help/#findComment-10255033
Overclocked Vega is known to draw >400w from the wall for the GPU alone...
Just some bapo nerd from 'Straya
PCs:
Main: i7 7700K (5GHz 1.4V) | ASUS GTX 1080 TURBO | 4x8GB Corsair Vengeance 3000MHz (3200MHz CL14 1.365V) | ASUS PRIME Z270-AR | Thermaltake SMART 750P | Coolermaster Seidon 240P | Acer Predator X34 (34" 1440p144Hz GSync IPS)
Secondary: i5 3570K | Intel HD4000 (RIP Sapphire HD 6850) | 2x2GB + 1x4GB Kingston 1600MHz | ASUS P8Z68-V LX | Corsair CX650 | Coolermaster Hyper D92 | Sony Bravia VPL-VW80 (108" 1080p60Hz projector)
Laptop: i7 7700HQ | GTX 1060 6GB MXM | 2x16GB SODIMM | OEM Acer Motherboard | 17.3" Screen (1080p60Hz IPS)
iMac: Core 2 Duo T7400 | ATI Radeon X1600 | 2x1GB 667MHz DDR2 | 20" Screen
https://linustechtips.com/topic/817373-good-psu-please-help/#findComment-10257755
12 minutes ago, Stefan Payne said:
You have any infos about power consumation of RX VEGA 56 and RX VEGA 64??
And why do you think that _SAITAMA_ would want one?!
Just pointing out that a single GPU can draw a fuckton of power.
Sauce: "Speaking of power consumption, the OC stepping table above shows some of that: Our overclocked Vega FE Hybrid mod had us around 33.3A at the rails, not counting PCIe power, for a GPU power consumption of 400W. That’s GPU power, not total system power (which is new for our tests, hence italics to emphasize). This is the limit for Vega, and is the reason we can’t OC higher.
We can’t yet measure at the PCIe interface, but we’re working on it. For now, we know that 33.3A * 12V = ~400W through the cables, plus whatever’s going through PCIe (up to 75W, by spec)."
- Stevey B from a Vega watercooled mod to test overclocking: http://www.gamersnexus.net/guides/2986-amd-vega-hybrid-mod-results-overclocking-liquid-vs-air/page-2
EDIT: This is Vega FE, RX 64 will draw less but I can still see it easily hitting 350+w after a decent OC...
Edited by awesomegamer919
PCs:
https://linustechtips.com/topic/817373-good-psu-please-help/#findComment-10258161
