Hello
I was messing around with ram timings today, trying to tighten them, when they became too tight, my PC would start to bootloop a few times, and then go to default settings, and boot to windows. (Set to detect bootlop 3 times in BIOS, then resetting to default settings)
So this happend a few times, and it was no problem, but now it dosent post at all, theres no bios screen or anything. Its on for about 20 seconds, then it turns off for something like 2 seconds, then starts again, but still no post screen. Fans and pump is running, but thats it. No USB peripherals or anything else is on. Should be noted that up until now, there has been no problems with the system, since I put it together 1,5 weeks ago.
I tried removing the CMOS battery for 15-20 mins.
Tried using only 1 of the sticks, in each ram slot, but nothing.
Got a youtube video I quickly filmed:
Shitty quality i know. It'll just keep doing this, forever.
PC Specs:
Motherboard: ASRock Fatal1ty x370 Gaming-ITX/AC - Updated to latest BIOS, AGESA 1.0.0.6a
CPU: Ryzen 1700
Ram: G.Skill Flare X 2x8GB @ 3200MHz, but ran at 2933, since 3200 was not stable.
Any ideas?
PC setup
Case: Fractal Define Nano S Windowed | Motherboard: ASRock Fatal1ty x370 Gaming-ITX/AC | CPU: Ryzen 1700 @ 3,8 GHz | GPU: Nvidia 1080 Ti Founders Edition | Ram: G.Skill Flare X @ 2933MHz | PSU: Corsair RM850
Cooling
CPU: EK Supremacy EVO | GPU: EK Block + Backplate | Rad: 2x EK-CoolStream SE 240 | Pump: EK XTOP DDC 3.2 | Res: EK-Res X3 110 | Fans: 4x Noctua NF-F12 iPPC-3000
Misc: EK fittings | EK Ekoolant EVO | EK Duraclear tubing
https://linustechtips.com/topic/817180-ryzen-not-posting/
2 minutes ago, UrthuaroBloodfist said:
sometimes you need to charge the board buy rubbing your socsk on shag carpet or something that will create an electric change, find a cap on your board (small round barrel looking object) then touch it , do that a few times. then press the power button. it will juice it up and good going
Yeah. I'm not gonna do that, but nice try. :-)
PC setup
Cooling
https://linustechtips.com/topic/817180-ryzen-not-posting/#findComment-10247530
Don't listen to the troll, it sounds like you've got a dead board. It happens sometimes. Hopefully, the RAM and CPU were effected.
--Michael "TheZorch" Haney
Content Creator for Zorch Central and Gamers Bay
Personal/Streaming Rig
  • AMD Ryzen 5 3600
  • 32 GB DDR4
  • 1 TB Intel 660p SSD
  • Gigabyte Radeon RX 5600 XT Windforce OC
  • Thermaltake 600 W 80+ Gold
Adobe Editing Rig
  • AMD Threadripper 1950X
  • 32 GB DDR4
  • 512 GB Samsung 960 Pro
  • x2 SLI Nvidia GeForce 1080 ti
  • Corsair 1200 W 80+ Platinum
https://linustechtips.com/topic/817180-ryzen-not-posting/#findComment-10247536
the troll just got banned
https://linustechtips.com/topic/817180-ryzen-not-posting/#findComment-10247569
8 minutes ago, Daniel Z. said:
it shouldnt be a dead board
yeah idk how a power cycling would brick a board although I did hear that it has happened to others on an am4 motherboard review so idk. maybe the same thing happened and they also just assumed the board was broken?
https://linustechtips.com/topic/817180-ryzen-not-posting/#findComment-10247604
turn off the PSU
unplug the power cable
take the cmos battery out again
Press the power button in for 2 seconds
unplug the EPS and 24pin
wait a few mins
put everything back
then see if it will post
https://linustechtips.com/topic/817180-ryzen-not-posting/#findComment-10247678
19 minutes ago, TrigrH said:
turn off the PSU
wait a few mins
put everything back
Still nothing
PC setup
Cooling
https://linustechtips.com/topic/817180-ryzen-not-posting/#findComment-10247746
7 minutes ago, TrigrH said:
do you unplug the battery cable or take the battery out?
I unplugged the battery cable. It's glued to the back of the rear Audio rear IO, you should be able to see the battery in the video
Edit: Just checked again, and its on there with something that looks like double sided thick adhesive tape
PC setup
Cooling
https://linustechtips.com/topic/817180-ryzen-not-posting/#findComment-10247764
