I am getting custom cables for my RM850i (8pin eps, 8pin pcie and 24pin atx)
And I got an email asking how many double wires(2 wires going into 1 pin) there are on those cables. I can't answer that at the moment as I'm at work.
Can anybody help me out?
Desktop Rig:
CPU: i7-6700K  Cooler: Noctua NH-L9x65  Graphics card: NVIDIA GeForce RTX 2080 Ti FE  Memory: Corsair VENGEANCE LED 3200Mhz (2x8GB)
Motherboard: ASUS ROG STRIX Z270i  SSD: Samsung 960 EVO 1TB, Samsung PM981 1TB  Case: Louqe Ghost S1
Monitor: Dell Alienware AW3418DW
https://linustechtips.com/topic/816750-rm850i-double-wires/
Google is your friend.
https://linustechtips.com/topic/816750-rm850i-double-wires/#findComment-10242953
I tried for a minute or two, but i can't spend much time on google when i'm working
Desktop Rig:
https://linustechtips.com/topic/816750-rm850i-double-wires/#findComment-10243087
The 24-Pin has 4x 2:1 wires. All PCIe cables have 1x 2:1 wire.
I would highly recommend you look at your own cable set and jot down exactly which wires are 2:1 for your record keeping. If you are truly stumped, I'm sure we could help you out.
https://linustechtips.com/topic/816750-rm850i-double-wires/#findComment-10247010
The fact that you're having custom cables made and the person making the cables doesn't already know this scares the crap out of me.  If they don't even know what wires are doubled up, how the heck are they going to get the pinout correct?  Modular cables are not one-to-one.
https://linustechtips.com/topic/816750-rm850i-double-wires/#findComment-10247925
I'm getting pre crimped cables, I'll be putting on the sleeves and connectors
Desktop Rig:
https://linustechtips.com/topic/816750-rm850i-double-wires/#findComment-10248175
I was asking because the guy I'm getting cables from goes on vacation today and he had to know to get my order shipped before that. Does the 8pin EPS cable have any 2:1 wires?
Desktop Rig:
https://linustechtips.com/topic/816750-rm850i-double-wires/#findComment-10248195
No, only ATX connector has, for reason I stated. And well, the PCie ( 2 grounds on one pin and 2 connectors on one cable)...
"Hell is full of good meanings, but Heaven is full of good works"
https://linustechtips.com/topic/816750-rm850i-double-wires/#findComment-10248279
