Posted August 3, 2017 I am thinking about purchasing the ryzen 1800x, but I just had a quick question about how all the cores work. I have 4 monitors. lets say for example I am playing a game that is hypothetically using 1-2 cores at 100% and want to tab over to some other program. Would core 3 then be assigned to that new program because it's free and ready for something to be thrown at it? Or is this not how CPUs work and hav I got it all wrong? Link to comment https://linustechtips.com/topic/816745-question-about-how-cores-work/ Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted August 3, 2017 kinda, having more cores just means you can do more things at once, without those things all happening on the same core. Home PC: CPU: i7 4790s ~ Motherboard: Asus B85M-E ~ RAM: 32GB Ballistix Sport DDR3 1666 ~ GPU: Sapphire R9 390 Nitro ~ Case: Corsair Carbide Spec-03 ~ Storage: Kingston Predator 240GB PCIE M.2 Boot, 2TB HDD, 3x 480GB SATA SSD's in RAID 0 ~ PSU: Corsair CX600 Display(s): Asus PB287Q , Generic Samsung 1080p 22" ~ Cooling: Arctic T3 Air Cooler, All case fans replaced with Noctua NF-B9 Redux's ~ Keyboard: Logitech G810 Orion ~ Mouse: Cheap Microsoft Wired (i like it) ~ Sound: Radial Pro USB DAC into 250w Powered Speakers ~ Operating System: Windows 10 Enterprise x64 Work PC: CPU: Intel Xeon E3 1275 v3 ~ Motherboard: Asrock E3C226D2I ~ RAM: 16GB DDR3 ~ GPU: GTX 460 ~ Case: Silverstone SG05 ~ Storage: 512GB SATA SSD ~ Displays: 3x1080p 24" mix and matched Dell monitors plus a 10" 1080p lilliput monitor above ~ Operating System: Windows 10 Enterprise x64 Link to comment https://linustechtips.com/topic/816745-question-about-how-cores-work/#findComment-10242826 Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted August 3, 2017 Just now, DnFx91 said: kinda, having more cores just means you can do more things at once, without those things all happening on the same core. but rule of thumb, the more you have, the slower they all have to run, and gaming performance usually takes a hit, given that games really like having a couple of fast cores, which is provided my almost every decent quadcore CPU on the market right now Home PC: CPU: i7 4790s ~ Motherboard: Asus B85M-E ~ RAM: 32GB Ballistix Sport DDR3 1666 ~ GPU: Sapphire R9 390 Nitro ~ Case: Corsair Carbide Spec-03 ~ Storage: Kingston Predator 240GB PCIE M.2 Boot, 2TB HDD, 3x 480GB SATA SSD's in RAID 0 ~ PSU: Corsair CX600 Display(s): Asus PB287Q , Generic Samsung 1080p 22" ~ Cooling: Arctic T3 Air Cooler, All case fans replaced with Noctua NF-B9 Redux's ~ Keyboard: Logitech G810 Orion ~ Mouse: Cheap Microsoft Wired (i like it) ~ Sound: Radial Pro USB DAC into 250w Powered Speakers ~ Operating System: Windows 10 Enterprise x64 Work PC: CPU: Intel Xeon E3 1275 v3 ~ Motherboard: Asrock E3C226D2I ~ RAM: 16GB DDR3 ~ GPU: GTX 460 ~ Case: Silverstone SG05 ~ Storage: 512GB SATA SSD ~ Displays: 3x1080p 24" mix and matched Dell monitors plus a 10" 1080p lilliput monitor above ~ Operating System: Windows 10 Enterprise x64 Link to comment https://linustechtips.com/topic/816745-question-about-how-cores-work/#findComment-10242831 Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted August 3, 2017 workload assignment is not up to the CPU and how many cores it has but to Windows' scheduler if you work with a lot of projects at the same time, you should consider in getting as much RAM as you can because each program opened needs it's own working set Link to comment https://linustechtips.com/topic/816745-question-about-how-cores-work/#findComment-10242845 Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted August 3, 2017 Quadcores dont have enough grunt to play newer games and multitask without making pretty large sacrifices to game performance. They can game OR do something else not so much game AND do something else. 99/100 times the windows kernel/scheduler will move threads around in a fairly optimal way. If you want that last little bit of performance you can manually set what programs use what cores in task manager. Link to comment https://linustechtips.com/topic/816745-question-about-how-cores-work/#findComment-10242852 Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted August 3, 2017 13 minutes ago, zMeul said: workload assignment is not up to the CPU and how many cores it has but to Windows' scheduler if you work with a lot of projects at the same time, you should consider in getting as much RAM as you can because each program opened needs it's own working set ^ Personally if you have alot of thing opened, you should look for more ram. My i7 6700k works fine while gaming when i have more than 20 PDF/word/ and around 40+ chrome tab open in background, as long it idling it shouldn't take my cpu process. It take around 12gb at idle with just a few chrome tab and basic softwares opened like steam,google play music,chrome tabs (20). When working 20-24 GB of ram at normal usage (for me) and around 28+ if gaming but this may vary depending how much each pdf / chrome or program you have opened. You shouldn't really worry much about the cpu but more your ram will be limiting in your situation. Magical Pineapples
