Looking for a way to control chassis fans to GPU temp. The CPU isn't really heating up enough to get the top/rear fans to pull hot air out of the cassis with my 1070FTW.
Any suggestions?
[FS][US] Corsair H115i 280mm AIO-AMD $60+shipping
System specs:
Asus Prime X370 Pro - Custom EKWB CPU/GPU 2x360 1x240 soft loop - Ryzen 1700X - Corsair Vengeance RGB 2x16GB - Plextor 512 NVMe + 2TB SU800 - EVGA GTX1080ti - LianLi PC11 Dynamic
https://linustechtips.com/topic/816423-sync-chassis-fan-to-gpu/
Your best bet is Speedfan, and setting a custom curve in the advanced options. I also control my temps on the 1070FTW instead of the CPU.
Someone already made a guide, you can probably get started with this;
https://linustechtips.com/topic/816423-sync-chassis-fan-to-gpu/#findComment-10239044
apparently not Ryzen ready.
any other suggestions?
System specs:
https://linustechtips.com/topic/816423-sync-chassis-fan-to-gpu/#findComment-10241564
