EKWB Aluminum custom kits
Solved by Oshino Shinobu,
With EK's kits, any of their X3 reservoirs should work fine. The size of the reservoir doesn't impact performance or pump requirements at all, it is pretty much entirely an aesthetic choice. They're mostly plastic besides the fittings, but there's no copper in them, no need to worry about mixing metals.
You may need to purchase more coolant as obviously a bigger reservoir will take more coolant to fill.
