This is my PC build: https://pcpartpicker.com/b/hWtgXL  Just recently I have started hearing a buzzing noise from my computer, and I thought it was a fan motor at first but today I found out I may be wrong. When I unplug a fan or two from one of the motherboards headers, the frequency of the buzzing changes. I am pretty sure it's not a fan motor, as I have tested extensively. What are your thoughts on this? Should I replace my PSU?
https://linustechtips.com/topic/816179-my-power-supply-is-buzzing/
Try fit in the power plugs more tightly. Just a bad connection between wires can cause buzzing when it conducts electricity.
Desktop benching:
Probably just coil whine, pretty normal so not much you can do (Harmless though).
Please quote our replys so we get a notification and can reply easily. Never cheap out on a PSU, or I will come to watch the fireworks.
PSU Tier List
My specs
PC:
CPU: Intel Core i5-6600K @4.8GHz
CPU Cooler: Noctua NH-U14S
Motherboard:  ASUS Maximus VIII Hero
GPU: Zotac AMP Extreme 1070 @ 2114Mhz
Memory: Corsair Vengeance LPX 16GB (2 x 8GB) DDR4-2400
Storage: Samsung 850 EVO-Series 500GB
Storage: Western Digital Caviar Blue 1TB
Case: Cooler Master MasterCase Pro 5
Power Supply: EVGA 750W G2
Peripherals
Keyboard: Corsair K70 LUX Browns
Mouse: Logitech G502
Headphones: Kingston HyperX Cloud Revolver
Monitor: U2713M @ 75Hz
I have coil whine on my video card, and the power supply doesn't sound similar to that. The sound is very deep and linear from the PSU.
Probably just low tier PSU syndrome.
Full Specs
Helios EVO (Main):
Pacific Spirit XT - Server
Delta - Laptop
