Monitor Splash Screen
Solved by GoodBytes,
You can't remove it, unless you have an option on the on screen menu (usually you don't).
Leaving the monitor in standby should not make it appear.
Usually the image is there to cover boot time of the monitor. Boot time can one or a combination of the following:
-> Back light warm up
-> Hardware detection with the graphic card
-> Input detection
-> Internal hardware boot up (monitors with color processors and all that)
Of course, it could be made on purpose as well, to show "Look! You've got an Acer! Please remember us!"
