Fan Optimization (lowering rpms)
So... I have a couple of standard fans in my case, hooked up to the motherboard.
Does anyone know of a software (or other methods in Bios (I have not found a good one in Bios)
that may be a 3rd part software to adjust the fan rpm aproxmently. Such as 500rpm (of max 2000rpm by fan).
FanMonitor does not work (3rd party)
To love is to risk not being loved in return. To hope is to risk pain. To try is to risk failure, but risk must be taken because the greatest hazard in life is to risk nothing.
https://linustechtips.com/topic/81543-fan-optimization-lowering-rpms/
So Fancontrollers wont work?
The only thing i can think of are some voltage regulators I think you can buy them cheaply 12,7,4v I think they are staged in.
I am sorry I forgot to sate this, software only please. Thank you.
What motherboard do you have? Also I think speedfan works.
MSI Z77A-G45 Gaming
Bios: 17.2 -will update to 17.3
speedfan (?) I think
Tried it. Didn't work.
Get low voltage adapters.
I can't really go hardware at this time. Plus with all BF no one will ship anything, on sale or not, until a few days.
"I could just order it, but I am a gamer; and waiting is not my game."
Go to a store after Black Friday and buy some, or order on Ebay.
Quote me to get a reply!
Any recommendations for software wise?
No, they aren't usually as good as a low voltage adapter.
Alright. Thanks either ways man.
I control my case fans with OpenHardwareMonitor. I'm pretty sure same can be done with HWmonitor also. You can't set rpm but precentage for fans. So set them at 100% and lower setting untill you are satisfied. BIOS setting should be as normal/default for this to work best.
^^^^ That's my post ^^^^
vvvv Who's there? vvvv
