Is there a pump/res combo that will fit in a 1.5in x 1.5in x 6in space?
If not is there a res that will fit? (could go with a cpu block with integrated pump)
Build: Intel S2600gz, 2x E5-2670, EVGA SC 1070, Zotac 1060 6GB mini, 48GB Micron 1333mhz ECC DDR3, 2x Intel DPS-750XB 750 watt PSU
https://pcpartpicker.com/user/elerek/saved/3T7D4D
https://linustechtips.com/topic/815417-need-really-small-pumpres/
Nothing that small with a proper pump, XSPC has the ION which is pretty small.
http://www.xs-pc.com/water-pumps/ion-pumpreservoir
i was looking at the ion just minutes ago. nice design and all that but a lot of 1 star amazon reviews. the usual reports of the device failing after a short while but also reports of it leaking out the hole where the power cable goes and other strange things.
anyone has personal experience with it ? i really like the look and the size
Haven't used it myself but it uses their own mini pump, not terrible for such a small size but not comparable to pumps like the DDC or D5.
http://thermalbench.com/2016/03/03/xspc-ion-pumpreservoir/2/
Throw as Alphacool Eisbaer solo in there and then you get pump + res + block all in one.
(or just say fuck it and buy an AIO unless you're also doing the GPU)
Workstation:  9800X3D|| Asus X670E ProArt Creator || MSI Gaming Trio 4090 Shunt || T.Force 7800CL34 || Corsair AX1600i@240V || whole-house loop.
LANRig/GuestGamingBox: 13700K @ Stock || MSI Z690 DDR4 || ASUS TUF 3090 650W shunt || Corsair SF600 || CPU+GPU watercooled 280 rad pull only || whole-house loop.
Server Router (Untangle): 13600k @ P-Core only || ASRock Z690 ITX || All 10Gbe || 2x8GB 3200 || PicoPSU 150W 24pin + AX1200i on CPU|| whole-house loop
Server Compute/Storage: 10850K @ 5.1Ghz || Gigabyte Z490 Ultra || EVGA FTW3 3090 1000W || LSI 9280i-24 port || 4TB Samsung 860 Evo, 5x10TB Seagate Enterprise Raid 6, 4x8TB Seagate Archive Backup ||  whole-house loop.
Laptop: HP Elitebook 840 G8 (Intel 1185G7) + 4070 RTX Thunderbolt Dock, Razer Blade Stealth 13" 2017 (Intel 8550U)
