1 hour ago, Optimus_Icecream said:
If a 2 fan radiator is 100$ would a 3 fan radiator be worth an extra 10$..
Yes as long as your case can house it a longer rad provide more cooling performance than shorter thicker rads.
-Moved to Liquid and Exotic Cooling-
https://linustechtips.com/topic/815024-radiator-thoughts/#findComment-10225056
Yes, generally speaking the fewer, bigger rads will always be the better/cheaper option so get the biggest you can fit.  When buying more smaller rads you are paying for the end tanks and fitting ports, etc.
LTT Community Standards                                               Welcome!-A quick guide for new members to LTT
Man's Machine- i7-7700k@5.0GHz / Asus M8H / GTX 1080Ti / 4x4gb Gskill 3000 CL15  / Custom loop / 240gb Intel SSD / 3tb HDD / Corsair RM1000x / Dell S2716DG
The Lady's Rig- G3258@4.4GHz(1.39v) on Hyper 212 / Gigabyte GA-B85M / gtx750 / 8gb PNY xlr8 / 500gb seagate HDD / CS 450M / Asus PB277Q
https://linustechtips.com/topic/815024-radiator-thoughts/#findComment-10225087
