Double 8-pin for GPU?
Go to solution Solved by another random person,
Just now, SirFido said:
The cables have names on them. The ones that are 6+2 have VGA written on them. Can i use them?
Yes VGA is the Graphics cards, look for the VGA power plug slots on your PSU.
Hey!
So yesterday i bought my first ever "not-laptop" computer and used all night building it. But when it came to powering my graphics card i had one question:
The Gigabyte Geforce GTX 1080 arous+ which i am using has two 8-pin connectors and not two 6-pin like the PSU i have has. What do i do? I have a modular PSU so should i connect a CPU 8-pin to power the GPU?
Thanks in advance!
https://linustechtips.com/topic/814769-double-8-pin-for-gpu/
4 minutes ago, SirFido said:
Hey!
Thanks in advance!
Never use CPU power for the GPU, what is the model and brand of your PSU?
I suck a typing, preparw for typos.
Desktop
CPU: Ryzen 7 3700x MOBO: MSI X570-A Pro RAM: 32 GB Corsair DDR4
GPUS: Gigabyte GTX 1660ti OC 6G  CASE: Corsair Carbide 100R STORAGE: Samsung Evo 960 500GB, Crucial P1 M.2 NVME 1TB   PSU: Corsair CX550M CPU COOLER: Corsair H100x
LAPTOP
Apple Macbook Pro 13 M1 Pro
https://linustechtips.com/topic/814769-double-8-pin-for-gpu/#findComment-10221617
Do not attempt to connect the CPU pins, they are keyed and will not fit (Will fry if you force, need it for CPU anyway). Could get a cheap adaptor as a temporary measure, but would probably be a good idea to buy a new one as this evidently isnt made to supply that much power.
Please quote our replys so we get a notification and can reply easily. Never cheap out on a PSU, or I will come to watch the fireworks.
PSU Tier List
My specs
PC:
CPU: Intel Core i5-6600K @4.8GHz
CPU Cooler: Noctua NH-U14S
Motherboard:  ASUS Maximus VIII Hero
GPU: Zotac AMP Extreme 1070 @ 2114Mhz
Memory: Corsair Vengeance LPX 16GB (2 x 8GB) DDR4-2400
Storage: Samsung 850 EVO-Series 500GB
Storage: Western Digital Caviar Blue 1TB
Case: Cooler Master MasterCase Pro 5
Power Supply: EVGA 750W G2
Peripherals
Keyboard: Corsair K70 LUX Browns
Mouse: Logitech G502
Headphones: Kingston HyperX Cloud Revolver
Monitor: U2713M @ 75Hz
https://linustechtips.com/topic/814769-double-8-pin-for-gpu/#findComment-10221622
6 minutes ago, SirFido said:
EVGA BQ 750w Hybrid Modular @another random person
On the spec sheet its stated that it has 3 of the 6+2 PCIE power  (8-Pins) Maybe take a second look in your PSU box for the cables.
Source:https://www.evga.com/products/product.aspx?pn=110-BQ-0750-V1
Desktop
LAPTOP
https://linustechtips.com/topic/814769-double-8-pin-for-gpu/#findComment-10221644
Your 6 pin connectors likely have a 2 pin connector cable hanging on it too, which you can use in your GPU.
GPU manufacturers like to call it '8 pin', but PSU manufacturers call it 6+2 pin (8 pin is used on the motherboard).
Check your PSU manual for the 6+2 connector.
https://linustechtips.com/topic/814769-double-8-pin-for-gpu/#findComment-10221646
https://linustechtips.com/topic/814769-double-8-pin-for-gpu/#findComment-10221647
Desktop
LAPTOP
https://linustechtips.com/topic/814769-double-8-pin-for-gpu/#findComment-10221650
