I can't understand most of what you're saying (proper punctuation splits up thoughts and makes them easier to read and understand). I think you're asking if you can install Sierra on your Mac? Yes, but what are the specs? You'll want at least 4GB of RAM (I'd recommend 8), and a 7200rpm drive (I'd recommend an SSD) It'll run without those, but will be terribly slow.
Gaming PC NAS Laptop Workstation
CPU: i5 12600KF 6P+4E Ryzen 7 3700X M4 SoC 4P+6E Xeon X5690 6c12t
Cooler: Noctua NH-D15S Wraith Stealth w/NF-A9 Passive Apple CPU Cooler
Motherboard: ASRock Z690 ITX/ax ASUS Pro B550M-C/CSM Apple J713AP Mac-F221BEC8 (Mac Pro 5,1)
RAM: 2x16GB 3600Mhz DDR4 2x16GB 2400MHz DDR4 24GB Micron LPDDR5 4x8GB 1333MHz ECC DDR3
GPU: Sapphire Pulse Radeon 9060 XT 16GB Radeon WX2100 M4 SoC 10C Radeon RX 5700
Storage: 1TB MP34 + 2TB P41 500GB SSD + 2x4TB IronWolf Pro in ZFS Mirror Apple AP0512Z 1TB Crucial MX500
ODD: LG WH14NS40 None LG GP65NB60 USB DVD Writer Don't know
PSU: EVGA 850W GM Silverstone SST-TX300 53.8Wh LiPo Battery Delta DPS-980BB
Case: Silverstone Sugo 14 Dell Inspiron 530S Mac16,12 chassis (13" MBA) 2009-2012 Mac Pro "Cheese Grater"
OS: Gentoo Linux TrueNAS Scale macOS 26 Tahoe Fedora Linux
Mouse: EVGA X17
Keyboard: Corsair K55 RGB
Mobile/Work Devices: 14" M5P MacBook Pro (work) - iPhone 17 Pro - Apple Watch S11
Other Misc Devices: iPod Video (Gen 5.5E, iFlash Solo w/128GB SD Card, Rockbox), Nintendo Switch
Vehicles: 2002 Ford F150, 2003 Harley-Davidson Sportster 1200, 2022 Kawasaki KLR650, 1994 DR350SE
it not mine it old dude from the 1960 who uses only ofor online videos and buy stuff he does not work for anything tech
It'll install just fine, but it'll have a hard time web browsing with only 2GB RAM. Also, non-techies often keep a massive amount of tabs open or never close stuff. I'd try and convince him to get an SSD and 4-8GB RAM. It'll run a lot smoother that way, and he won't keep coming to you and complaining that it's slow.
Mouse: EVGA X17
i try it maybe ram if it lowest price maybe but ssd he is old man who dont wanna work and he is like old people who you can buy nickle for gum or anything in the life in the past is there any low price rams for this
I'd check out Crucial or OWC to see what type of RAM you need, then look on eBay for lower prices. And an SSD makes a massive difference, especially to old people, since it seems so fast.
Mouse: EVGA X17
i check it says 56dollers for 4 kit and it says  ct3373691 ddr2 667
Then you need to look for 4-8GB of PC2-5300 RAM. You’ll need 2-4GB sticks, since it can only take 2, IIRC.
Mouse: EVGA X17
can this work http://www.ebay.com/itm/4GB-2X2GB-DDR2-RAM-APPLE-MAC-BOOK-MACBOOK-PRO-MEMORY-STICKS-667MHz-PC2-5300-A37-/272059980771?epid=1752235320&hash=item3f5809dbe3:g:i8wAAOSwAvJW9r64
It should, though I've never heard of that brand before, so be cautious.
Mouse: EVGA X17
