GPU not running 100% on certain games
Go to solution Solved by Dujith,
Hots is not really made for alot of FPS and is much more CPU dependent. It also has a lower tick rate then Overwatch which was 20 not long ago.
So should not matter tbh
CPU = 5930k OC to 4.0GHz no CPU Bottleneck
When running Ghost Recon Wildlands GPU is pegged at around 100% with GPU clocked at 2088Mhz.
When running Heroes of the Storm, GPU is pegged at around 32-37% with GPU clocked at 1747Mhz.
I own a 144Hz monitor and this only makes my game run at 120FPS, when I bump the game from Medium to Extreme it makes my game run at 90FPS without making the GPU usage or clock go any higher.
Searched the internet, I have done these 2 things.
1) In Nvidia Control Panel, changed power management to Prefer Maximum Settings. Did not work, I changed it back to default.
2) Max out the setting, all the did was make my FPS lower without affect GPU usage/clocks.
Help appreciated.
https://linustechtips.com/topic/814191-gpu-not-running-100-on-certain-games/
What gpu do you have?
Current LTT F@H Rank: 24    Score: 10,097,484,643   Stats
Yes, I have 9 monitors.
My main PC:
OS: Windows 11
CPU: Ryzen 9 9950X
Cooler: Noctua NH-D15
Mobo: Asus ProArt X670E Creator WiFi
RAM: 96GB Trident Z Neo @6400 CL32
GPU: RTX 4090 Founders Edition, Radeon Pro WX 5100
PSU: Corsair RM1000e
SSDs: Samsung 990 Pro 4TB NVME, Samsung 970 evo plus 1TB NVME, 2x Samsung 870 evo 2TB, Samsung 860 evo 1TB, Samsung 970 evo 500GB NVME
Case: Fractal Design Define R5 Black w/ Tempered Glass Side Panel Upgrade
Monitors: 9 Monitors: Alienware AW3423DWF 3440x1440@165Hz, Acer H236HLbid 1080p@77Hz, HP D7z72AA 1080p@60Hz, Dell Inspiron 24 3459 1080p@60Hz(used only as display), Dell U2724D 1440p@120Hz, ASUS VP228 1080p@60Hz, 2x HP ZR2440W 1200p@60Hz
unRAID server (Plex, Backups, NAS, Duplicati, game servers):
OS: unRAID 7.1.4
CPU: Ryzen R9 3900X
Cooler: Noctua NH-U9S
Mobo: Asus ROG Strix X470-F
RAM: 64GB G-Skill Ripjaws V @ 3200MHz
PSU: EVGA G3 850W
Total Storage: Raw: 94TB, Usable: 64TB
SSD: Samsung 990 Pro 2TB NVME, Teamgroup 4TB NVME
HDDs: 4x HGST Dekstar NAS 4TB @ 7200RPM (3 data, 1 parity) + (7x Seagate Ironwolf NAS 8TB + 2x Toshiba N300 NAS 8TB in ZFS)
Case: Fractal Define 7 XL
Other: Added 3x Noctua NF-F12 intake, 2x Noctua NF-A8 exhaust, Inatek 5 port USB 3.0 expansion card with usb 3.0 front panel header
What's the matter with 100% GPU usage? That's what you want, it means you aren't bottle necked at all. I would kill to have my GPU have 100% usage in Wildlands and BF1
Edited by Max_Settings
NVM missread titles
I see. That's not great, I wanted to hit the 144FPS mark.
Ghost Recon is just on there to show that there's no CPU bottleneck.
