It needs to be either ATX or Micro-ATX with solid airflow. Looking for as many suggestions as I can get. Cheaper is better but try to keep it looking decent.
Main Gaming PC - i9 10850k @ 5GHz - EVGA XC Ultra 2080ti with Heatkiller 4 - Asrock Z490 Taichi - Corsair H115i - 32GB GSkill Ripjaws V 3600 CL16 OC'd to 3733 - HX850i - Samsung NVME 256GB SSD - Samsung 3.2TB PCIe 8x Enterprise NVMe - Toshiba 3TB 7200RPM HD - Lian Li Air
Proxmox Server - i7 8700k @ 4.5Ghz - 32GB EVGA 3000 CL15 OC'd to 3200 - Asus Strix Z370-E Gaming - Oracle F80 800GB Enterprise SSD, LSI SAS running 3 4TB and 2 6TB (Both Raid Z0), Samsung 840Pro 120GB - Phanteks Enthoo Pro
Super Server - i9 7980Xe @ 4.5GHz - 64GB 3200MHz Cl16 - Asrock X299 Professional - Nvidia Telsa K20 -Sandisk 512GB Enterprise SATA SSD, 128GB Seagate SATA SSD, 1.5TB WD Green (Over 9 years of power on time) - Phanteks Enthoo Pro 2
Laptop - 2019 Macbook Pro 16" - i7 - 16GB - 512GB - 5500M 8GB - Thermal Pads and Graphite Tape modded
Smart Phones - iPhone X - 64GB, AT&T, iOS 13.3 iPhone 6 : 16gb, AT&T, iOS 12 iPhone 4 : 16gb, AT&T Go Phone, iOS 7.1.1 Jailbroken. iPhone 3G : 8gb, AT&T Go Phone, iOS 4.2.1 Jailbroken.
https://linustechtips.com/topic/813157-best-case/
13 minutes ago, Droidbot said:
S340 or Dukase
S340 is like one of the worst for airflow tho and the Dukase is a bit on the expensive side.
https://linustechtips.com/topic/813157-best-case/#findComment-10204135
Just now, Corsair Blake said:
Check out the new CARBIDE Series SPEC-04 case. Full ATX and solid airflow with a radical design.
I was able to fit a bunch of stuff into it and kept it very clean.
http://www.corsair.com/~/media/60C6030DB77C4A1393D2B7C100C0DACE.ashx?w=780
My friend, who I'm posting this for, are actually thinking about this case. Gonna have to try to get him to OK the side power button + USB ports tho.
https://linustechtips.com/topic/813157-best-case/#findComment-10204272
Coolermaster's Masterbox lite 5 looks pretty good for $55.
https://linustechtips.com/topic/813157-best-case/#findComment-10205028
Another good case to look at is Fractal Design Focus G
11-352-069-V17.jpg?w=660&h=500
MasterBox Lite 5
11-119-322-V01.jpg?w=660&h=500
The front panel is semi clear
11-119-322-V22.jpg?w=660&h=500
11-119-322-V23.jpg?w=660&h=500
11-119-322-V21.jpg?w=660&h=500
https://linustechtips.com/topic/813157-best-case/#findComment-10206690
