Ethernet Cables same at patch?
Go to solution Solved by Who Leo,
2 minutes ago, W-L said:
Patch cables are basically pre-terminated ethernet cables that come in different lengths. For crimps Monoprice has good ones.
https://www.monoprice.com/product?p_id=7266
would u recommend any from amazon? I have amazon prime and I would like to have my cables done ASAP for CAT5E
14 minutes ago, 2003leohu said:
I have a 50 meter cat5e cable that i presume has a broken connector
I am trying to do DIY rj45 ethernet cables and I was wondering if the 50m cat5e cable is the same thing as patch cables.
Does anyone also know a good crimping rj45 header for cheap on amazon?
