A note on the CPU.  You are not going to get a whole lot of points from it.  Also, F@H tends to not be friendly to odd count on threads.  Usually best to set to even thread count (ex. 2, 4, 6, etc.)
Have you brought up the advance view?  From there you can look at the log files while F@H runs, that will give far more information then looking at the webview.
2023 BOINC Pentathlon Event
F@H & BOINC Installation on Linux Guide
My CPU Army: 5800X, E5-2670V3, 1950X, 5960X J Batch, 10750H *lappy
My GPU Army:3080Ti, 960 FTW @ 1551MHz, RTX 2070 Max-Q *lappy
My Console Brigade: Gamecube, Wii, Wii U, Switch, PS2 Fatty, Xbox One S, Xbox One X
My Tablet Squad: iPad Air 5th Gen, Samsung Tab S, Nexus 7 (1st gen)
3D Printer Unit: Prusa MK3S, Prusa Mini, EPAX E10
VR Headset: Quest 2
Hardware lost to Kevdog's Law of Folding
OG Titan, 5960X, ThermalTake BlackWidow 850 Watt PSU
I'll fix the thread count. anything is should be looking for in the logs?
There should be radio buttons to only show the GPU.  Best to watch and see if any fails are occurring.  Is MSI Afterburner still showing a very low usage on the GPU?
Here is what advance view looks like:
Also, you applied a passkey?
VR Headset: Quest 2
16 hours ago, LiquidMotionz said:
from my log
23:13:45:WU01:FS01:0x21:Bad State detected... attempting to resume from last good checkpoint. Is your system overclocked?
Do you have the card overclocked?  Best thing to do is screen shot the log.  Could be that the cards is not stable while folding.
Unfortunately, I don't do discord and seems we are on a large time gap (I'm on Zulu time at the moment).  Plus, some sites and traffic is blocked at the country I am deployed at (heck, Wikipedia is blocked...).
VR Headset: Quest 2
https://pastebin.com/B4GuKree is my log for about 8 hours, and it is only factory overclocked nothing i can change about that
  • 4 years later...
Did y'all ever fix this old issue? My 3080 gets low usage, and i have a thread set aside for this
Edit: Sorry for resurrecting this I checked msi afterburner after finding a reddit thread recommending that
Edited by gamagama69
