I figure just looking at stock clockspeeds. I know people say you can overclock to where they all match but that's not a guarantee. I figure a 1700 that can OC to 4GHz would have been binned as a 1700x or 1800x.
So anyone have an idea what the best R7 or R5 is for use in VR gaming/?
https://linustechtips.com/topic/812082-best-ryzen-cpu-for-vr/
R5 1600 or R7 1700 would probably be the ideal choices.
Community Standards
"Beast Mode"
Dedicated Streaming Rig
https://linustechtips.com/topic/812082-best-ryzen-cpu-for-vr/#findComment-10191841
They should alleviate any CPU bottleneck you would have with the 6 and 8 cores they provide.
Community Standards
"Beast Mode"
https://linustechtips.com/topic/812082-best-ryzen-cpu-for-vr/#findComment-10191878
The R7 1700 is currently selling for $299 on Newegg. You can get a pre-binned 1700 that is validated to 3.9GHz for $289 at SiliconLottery.
https://siliconlottery.com/collections/pga-1331/products/1700a39g
https://linustechtips.com/topic/812082-best-ryzen-cpu-for-vr/#findComment-10191888
Just now, Sin Stalker said:
I don't understand . They both have different core counts.
ok. the intel 7700k has 4 physical cores. the amd 1600 has 6 physical cores, and then 1700 has 8 phisical cores. the 1700, is like 40-50$ USD cheaper than the 4 core 7700k.
https://linustechtips.com/topic/812082-best-ryzen-cpu-for-vr/#findComment-10191892
Just cause they could boot it to 3.9 doesn't mean its stable there.
https://linustechtips.com/topic/812082-best-ryzen-cpu-for-vr/#findComment-10191896
They run RealBench on a loop for an hour to validate it...but hey don't bother reading anything and just make assumptions xD
https://linustechtips.com/topic/812082-best-ryzen-cpu-for-vr/#findComment-10191988
Um I really think they do more than that otherwise they would have no market
My daily driver: The Wrath of Red: OS Windows 10 home edition / CPU Ryzen TR4 1950x 3.85GHz / Cooler Master MasterAir MA621P Twin-Tower RGB CPU Air Cooler / PSU Thermaltake Toughpower 750watt / ASRock x399 Taichi / Gskill Flare X 32GB DDR4 3200Mhz / HP 10GB Single Port Mellanox Connectx-2 PCI-E 10GBe NIC / Samsung 512GB 970 pro M.2 / ASUS GeForce GTX 1080 STRIX 8GB / Acer - H236HLbid 23.0" 1920x1080 60Hz Monitor x3
My technology Rig: The wizard: OS Windows 10 home edition / CPU Ryzen R7 1800x 3.95MHz / Corsair H110i / PSU Thermaltake Toughpower 750watt / ASUS CH 6 / Gskill Flare X 32GB DDR4 3200Mhz / HP 10GB Single Port Mellanox Connectx-2 PCI-E 10GBe NIC / 512GB 960 pro M.2 / ASUS GeForce GTX 1080 STRIX 8GB / Acer - H236HLbid 23.0" 1920x1080 60Hz Monitor HP Monitor
My I don't use RigOS Windows 10 home edition / CPU Ryzen 1600x 3.85GHz / Cooler Master MasterAir MA620P Twin-Tower RGB CPU Air Cooler / PSU Thermaltake Toughpower 750watt / MSI x370 Gaming Pro Carbon / Gskill Flare X 32GB DDR4 3200Mhz / Samsung PM961 256GB M.2 PCIe Internal SSDEVGA GeForce GTX 1050 Ti SSC GAMING / Acer - H236HLbid 23.0" 1920x1080 60Hz Monitor
My NAS: The storage miser: OS unRAID v. 6.9.0-beta25 / CPU Intel i7 6700 / Cooler Master MasterWatt Lite 500 Watt 80 Plus / ASUS Maximus viii Hero / 32GB Gskill RipJaw DDR4 3200Mhz / HP Mellanox ConnectX-2 10 GbE PCI-e G2 Dual SFP+ Ported Ethernet HCA NIC / 9 Drives total 29TB - 1 4TB seagate parity - 7 4TB WD Red data - 1 1TB laptop drive data - and 2 240GB Sandisk SSD's cache / Headless
Why did I buy this server: OS unRAID v. 6.9.0-beta25 / Dell R710 enterprise server with dual xeon E5530 / 48GB ecc ddr3 / Dell H310 6Gbps SAS HBA w/ LSI 9211-8i P20 IT / 4 450GB sas drives / headless
Just another server: OS Proxmox VE / Dell poweredge R410
https://linustechtips.com/topic/812082-best-ryzen-cpu-for-vr/#findComment-10192088
Maybe, but looking at their site, I see claims of testing but no guarantees. You'd think their warrranty would cover the cpu not being stable at their tested value... but I can't find it...
https://linustechtips.com/topic/812082-best-ryzen-cpu-for-vr/#findComment-10192098
You probably won't to many variables i.e. water cooled vs air cooled hardware such as motherboard and psu
https://linustechtips.com/topic/812082-best-ryzen-cpu-for-vr/#findComment-10192129
