Fan controller for 12 fans
CyberFern0
Thermaltake has one and no double posting I seen the other one last night :)
Im mostly on discord now and you can find me on my profile
My Build: Xeon 2630L V, RX 560 2gb, 8gb ddr4 1866, EVGA 450BV
My Laptop #1: i3-5020U, 8gb of DDR3, Intel HD 5500
oh then why didnt u reply to it
whats it called
is it good?
Highest i can find from thermaltake is a 10 fan hub, the commander fp
PC - CPU Ryzen 5 1600 - GPU Power Color Radeon 5700XT- Motherboard Gigabyte GA-AB350 Gaming - RAM 16GB Corsair Vengeance RGB - Storage 525GB Crucial MX300 SSD + 120GB Kingston SSD   PSU Corsair CX750M - Cooling Stock - Case White NZXT S340
Peripherals - Mouse Logitech G502 Wireless - Keyboard Logitech G915 TKL  Headset Razer Kraken Pro V2's - Displays 2x Acer 24" GF246(1080p, 75hz, Freesync) Steering Wheel & Pedals Logitech G29 & Shifter
will hte nzxt sentry 3 handle 12 fans?
I was really tired
whats it called
is it good?
I can't remember and I don't use it personally
You can literally just find that out from looking the specs on any site that sells it.
no, it can only do 5. If you really wanted to you can probably use some splitters to get more than 5 on it though.
Go with two hubs or controllers as others have said. Just curious why you need 12 fans though?
i5 6600k @ 4.4ghz on Hyper 212 Evo
Powercolor RX 480 8Gb Red Devil @1330Mhz
Bottom line:  Don't be a spaz or an 800lb gorilla when installing your expensive CPU, and you won't have any problems. --Phate.exe
