Hello, I have just finished building my pc and I noticed that the front panel USB ports can't detect USB drives. I know that the USB port itself is working since my wireless mouse and keyboard are working on it but I just can't open files from a USB drive connected to it. What should I do?
https://linustechtips.com/topic/810280-usb-drive-not-detected/
Make sure that there isn't anything USB related disabled in the BIOS that shouldn't be.
Otherwise, the port just might not be able to support that type of data transfer or have enough power to power the USB storage device. If you have other available USB ports to use, then I would just use them and use the front ones for your keyboard and mouse and not worry about it.
https://linustechtips.com/topic/810280-usb-drive-not-detected/#findComment-10172407
What format is the USB drive in? Does Windows even acknowledge that a drive is connected or is it completely oblivious to it? What I'm getting from your post is that the drive is listed in Windows Explorer, but when you try to open, it says you need to format the drive in order to use it. Which in that case, you either have a drive that is corrupted or formatted in a file system that Windows cannot read natively (like Apple's HFS+: Mac OS Extended).
Intel® Core™ i7-12700 | GIGABYTE B660 AORUS MASTER DDR4 | Gigabyte Radeon™ RX 6650 XT Gaming OC | 32GB Corsair Vengeance® RGB Pro SL DDR4 | Samsung 990 Pro 1TB | WD Green 1.5TB | Windows 11 Pro | NZXT H510 Flow White
Sony MDR-V250 | GNT-500 | Logitech G610 Orion Brown | Logitech G402 | Samsung C27JG5 | ASUS ProArt PA238QR
iPhone 12 Mini (iOS 18.3) | iPhone 15 (iOS 18.3.1) | KZ AZ09 Pro x KZ ZSN Pro X | Sennheiser HD450bt
Intel® Core™ i7-1265U | Kioxia KBG50ZNV512G | 16GB DDR4 | Windows 11 Enterprise | HP EliteBook 650 G9
Intel® Core™ i5-8520U | WD Blue M.2 250GB | 1TB Seagate FireCuda | 16GB DDR4 | Windows 11 Home | ASUS Vivobook 15
Intel® Core™ i7-3520M | GT 630M | 16 GB Corsair Vengeance® DDR3 |
Samsung 850 EVO 250GB | macOS Catalina | Lenovo IdeaPad P580
https://linustechtips.com/topic/810280-usb-drive-not-detected/#findComment-10172471
No, windows doesn't even acknowledge that there is a USB flash drive but my wireless mouse works with that port.
https://linustechtips.com/topic/810280-usb-drive-not-detected/#findComment-10172556
