Do I need a number pad for programming?
Short answer, no, you don't need one. Longer answer, you are unlikely to see much benefit from one unless 1) you've always had a numpad, and thus just never learned to type on the number row, 2) you are constantly entering numeric values. E.g., hard-coding some arrays, manually specifying numeric coefficients in mathematical equations, or doing data-entry type activities. For that, a numpad tends to speed me up a lot, but only when I'm entering many numbers in succession without needing to jump back to the main keyboard area.
So if you want a TKL, get a TKL. You can always get a dedicated, perfectly usable USB numpad for pretty cheap if you find yourself really needing one later. Or, I think there are some keyboard that have a detachable numpad section.
