Can anyone help me?
Go to solution Solved by The Sloth,
VGA to HDMI adapter
9 minutes ago, Tran said:
thank you, a friend gave me an adapter but it had somthing next to the pins so it didn't fit
That would be a dvi to vga.
Look for a DP to VGA cord.
QUOTE/TAG ME WHEN RESPONDING
Please Spend As Much Time Writing Your Question As You Want Me To Spend Responding To It. Take Time & Explain
New TOS RUINED the meme that used to be below :(
https://linustechtips.com/topic/809420-can-anyone-help-me/#findComment-10163375
