How many watts will i need for this rig:
MB: Gigabyte GA-AB350M-Gaming 3 (rev. 1.0)
CPU: AMD Ryzen 5 1500x Box
RAM: HyperX Fury 8GB DDR4 2400MHz HX424C15FB2/8 DIMM
Storage: Corsair Force Series™ LE200 CSSD-F120GBLE200 120GB SSD and Seagate Barracuda ST1000DM010 1TB
GPU: Gigabyte NVIDIA GeForce GTX 1050Ti G1 Gaming 4G GV-N105TG1 GAMING-4GD 4GB GDDR5
Case: Fractal Design Define C(i know that the case doesn't matter)
https://linustechtips.com/topic/809293-how-many-watts-do-i-need/
That system will draw around 200W under max load. A Corsair CX450 would be fine.
2 minutes ago, Versti said:
will i be able to overclock? like will a 450W PSU be able to handle giving power to my overclocked parts?
Yes. Assuming TDP is power consumption (I know it's not), at worst case, you could be pulling 65W. Overclocking by 10% theoretically only increases that by 10%, i.e., it adds 6W.
That's not how it works btw. The voltage-power relationship is not linear but has an exponential component which means hypothetically a 10% voltage increase can lead to a 20% power increase, then another 10% increase on top of that can lead to a 50% power increase. (these values are made up but the point is it is not linear.
Primary PC-
CPU: Intel i7-6800k @ 4.2-4.4Ghz   CPU COOLER: Bequiet Dark Rock Pro 4   MOBO: MSI X99A SLI Plus   RAM: 32GB Corsair Vengeance LPX quad-channel DDR4-2800  GPU: EVGA GTX 1080 SC2 iCX   PSU: Corsair RM1000i   CASE: Corsair 750D Obsidian   SSDs: 500GB Samsung 960 Evo + 256GB Samsung 850 Pro   HDDs: Toshiba 3TB + Seagate 1TB   Monitors: Acer Predator XB271HUC 27" 2560x1440 (165Hz G-Sync)  +  LG 29UM57 29" 2560x1080   OS: Windows 10 Pro
Album
Other Systems:
Home HTPC/NAS-
CPU: AMD FX-8320 @ 4.4Ghz  MOBO: Gigabyte 990FXA-UD3   RAM: 16GB dual-channel DDR3-1600  GPU: Gigabyte GTX 760 OC   PSU: Rosewill 750W   CASE: Antec Gaming One   SSD: 120GB PNY CS1311   HDDs: WD Red 3TB + WD 320GB   Monitor: Samsung SyncMaster 2693HM 26" 1920x1200 -or- Steam Link to Vizio M43C1 43" 4K TV  OS: Windows 10 Pro
Offsite NAS/VM Server-
CPU: 2x Xeon E5645 (12-core)  Model: Dell PowerEdge T610  RAM: 16GB DDR3-1333  PSUs: 2x 570W  SSDs: 8GB Kingston Boot FD + 32GB Sandisk Cache SSD   HDDs: WD Red 4TB + Seagate 2TB + Seagate 320GB   OS: FreeNAS 11+
Laptop-
CPU: Intel i7-3520M   Model: Dell Latitude E6530   RAM: 8GB dual-channel DDR3-1600  GPU: Nvidia NVS 5200M   SSD: 240GB TeamGroup L5   HDD: WD Black 320GB   Monitor: Samsung SyncMaster 2693HM 26" 1920x1200   OS: Windows 10 Pro
Having issues with a Corsair AIO? Possible fix here:
Are you getting weird fan behavior, speed fluctuations, and/or other issues with Link?
Are you running AIDA64, HWinfo, CAM, or HWmonitor? (ASUS suite & other monitoring software often have the same issue.)
Corsair Link has problems with some monitoring software so you may have to change some settings to get them to work smoothly.
-For AIDA64: First make sure you have the newest update installed, then, go to Preferences>Stability and make sure the "Corsair Link sensor support" box is checked and make sure the "Asetek LC sensor support" box is UNchecked.
-For HWinfo: manually disable all monitoring of the AIO sensors/components.
-For others: Disable any monitoring of Corsair AIO sensors.
That should fix the fan issue for some Corsair AIOs (H80i GT/v2, H110i GTX/H115i, H100i GTX and others made by Asetek). The problem is bad coding in Link that fights for AIO control with other programs. You can test if this worked by setting the fan speed in Link to 100%, if it doesn't fluctuate you are set and can change the curve to whatever. If that doesn't work or you're still having other issues then you probably still have a monitoring software interfering with the AIO/Link communications, find what it is and disable it.
Just now, turkey3_scratch said:
Neh max load will probably be in the 160s.
i've measured power use before when stress testing computers. GPU TDP is very accurate when you are stress testing. Ofcourse game power usage is way lower but you have to remember that there are peaks and max use.
CPU doesnt use much power, GPU is about 150W so add the entire thing together (CPU, motherboard, drives, fans) and you get about 300W total max use, and including for additional peripherals attached and for anything added in the future, 450W gives added space including for any peaks.
I'm going off Intel's derived equation of P = C * V^2 * f. So while yes, increasing voltage causes an exponential growth, frequency is many orders of magnitude higher than voltage. At 1.5v, increasing it to 1.6v is not going to have much of an an impact than going from 3,600,000,000 to 4,000,000,000 or whatever.
@pyrojoe34
Okay, nevermind, I did some math and for the same frequency, yes, the power does grow quite a bit. But if all you're touching is frequency then it's a linear relationship.
Yes it will. Plug in some numbers to see:
I omitted C since I will assume it doesn't change for the sake of this point.
P = 1.52 * 3.6 = 8.1
P = 1.52 * 4.0 = 9 (this is linear 11% increase in freq leads to 11% increase in power)
P = 1.62 * 3.6 = 9.216 (6.7% increase in voltage leads to 13.8% increase in power)
P = 1.62 * 4.0 = 10.24  (11% increase in performance leads to 26.4% increase in power. Just showed this one since you would usually have to increase voltage as well to increase frequency to get a stable OC.)
If you want a less hypothetical example:
i7-6800k
Stock: 3.6Ghz (turbo), ~1.15V, 98W
OC1: 4.0Ghz (11% increase), 1.2V (4% increase), 119W (21% increase)
OC2: 4.4Ghz (10% increase from OC1, 22% from stock), 1.45V (21% increase from OC1, 26% from stock), 177W (49% increase from OC1, 81% from stock)
Primary PC-
Album
Other Systems:
Home HTPC/NAS-
Laptop-
We're both talking about a GTX 1050Ti, right? Or are you talking about something else? Also, instantaneous spikes are not talked about when speaking of "power consumption". Average power is what's important.
For estimating power cost sure. But for PSU requirements the peak is what is important. If the peak is higher than the PSU can handle, even if the average is not, then you will have issues.
Primary PC-
Album
Other Systems:
Home HTPC/NAS-
Laptop-
This is not true. The PSUs are made with a lot of tolerance to handle spikes. Average is what is important. Look at a GTX 1050Ti review, the reported power is average. It is not 150W like you say.
Also, I'm talking about peak instantaneous not peak average. What are you talking about?
Again this all comes down to the PSU specs. Most are rated for both a peak output and a continuous output. The advertised usually (but not always) wattage refers to the continuous output. For example I have a PSU that's rated for 500W continuous 538W peak. Either way you want to keep your peak below the rated wattage to be safe, getting a PSU that's 50 or 100W higher than another in the same tier is usually just a few bucks more expensive and worth the safety margin IMO.
OP: A 450W PSU would be plenty for you and leave lots of headroom for OC and future upgrades. Since a 550W is usually just a few dollars more then you can also opt for that for even more future flexibility.
Primary PC-
Album
Other Systems:
Home HTPC/NAS-
Laptop-
HardOCP reviews are good for wattage. Here: https://www.hardocp.com/article/2016/10/25/msi_geforce_gtx_1050_ti_gaming_x_4g_review/11
The test setup is an I7-6700K @4.7Ghz and the MSI GTX 1050Ti. Gaming wattage measured from the wall without overclocking is 162W, with overclocking it is 175W. PSU used is the Corsair CX850M. Going by the review here http://www.jonnyguru.com/modules.php?name=NDReviews&op=Story4&reid=427 efficiency is probably around 84.5%, making gaming wattage 138W for the whole system without OC or about 150W with overclocking.
The Ryzen 5 1500X will use a lot less power than the I7 overclocked heavily. So OP's wattage when gaming is probably going to be more around 125-130W.
anyone remember one of linus videos where he stuffed loads of GPUs with a PSU that was just enough? It tripped the protection.
You gotta worry about peaks, future upgrades and efficiency.
A PSU is most efficient when at a particular use, this is good on both power bill and voltage stability and heat.
Components can be changed or added and use more power.
Peak power that is more than the PSU's wattage can trip protections and blow fuses.
So if you can afford a better PSU go for it. Wattage isnt everything on the PSU though but as long as the 12V output is 90% of the rated watts at least and that the PSU has a clean output than it will be decent. Protection features are good.
Sure the gaming wattage is low, but software isnt predictable, games all differ and power use differ. This is why you use stress test and not gaming wattage as every game is different and some games can use more power.
So 450W is a good estimate to cover all 3 needs. Even peripherals like usb need power so devices that are attached will draw power too.
