Hello guys.
I have built a Ryzen rig 2 days ago and somehow it freezes from 1-5 seconds from time to time. Sometimes it is when i'm starting up with windows, sometimes it is when I am playing games (csgo, lol). And sometimes my mouse stutters and skips.
Here is my build:
CPU: Ryzen R5 1600
GPU: ASUS GeForce Expedition GTX 1050Ti OC Edition 4GB GDDR5
MB: MSI B350M Mortar
RAM: G. Skill Aegis Gaming 16gb (2x8gb) 3000MHz cl16, (I used XMP profile and its at 2933MHz)
HDD: WD Blue 1 TB
SSD: Samsung PM961 Polaris 256GB M.2 PCIe NVMe 3.0x4
Antec Neoeco II Series 450W
- I have updated all the drivers, AND flashed the newest BIOS too.
- I used MSI afterburner to monitor when playing games and the CPU/GPU are at optimal temperature and not at 100%, constantly getting 200-300 fps, but somehow I still get sudden freezes.
Can someone please help? The sudden freezes are VERY annoying.
Could it be the rams? or a faulty windows 10?
P.S. I checked error logs and this one keeps appearing: Activation context generation failed for "c:\program files\amd\cim\bin64\SetACL64.exe". Dependent Assembly Microsoft.VC80.MFC,processorArchitecture="amd64",publicKeyToken="1fc8b3b9a1e18e3b",type="win32",version="8.0.50608.0" could not be found. Please use sxstrace.exe for detailed diagnosis.
could it be the problem?
https://linustechtips.com/topic/808675-problem-with-my-ryzen-build/
3 minutes ago, RGProductions said:
Could be ram, ryzen is picky with ram, however I think it could be your psu bring inadequate for the build.
Whats the problem with the PSU? Ryzen 1600 has 65W TDP and the GTX 1050 Ti 75W. It could easily run on a 300W PSU:
Main PC: CPU Xeon E3-1231 V3 - MB Asrock B85M Pro3 - RAM 16GB Kingston - GPU GTX 1070 Gainward Phoenix - PSU Corsair AX760i - Monitor  LG 22EA63 - Keyboard Corsair Strafe - Mouse Logitech G402 - Storage 2x3TB WD Green - 240GB OCZ SSD
10 minutes ago, kentcheung92 said:
Hello guys.
Update ALLLLLLL of your VC-Redistributables (2005/2008/2010/Everything)
If they are installed already - Reinstall/Repair them.
The last 10 articles I've read ALL solved,....point to VC-Redist.
As for your other freezing... well so many apps use the redistributables so this could even be your issue.
(Windows update/game installs) usually update VCREDIST setups for you.... but errors and bugs happen too.
Repair them.
https://support.microsoft.com/en-gb/help/2977003/the-latest-supported-visual-c-downloads
Maximums - Asus Z97-K /w i5 4690 Bclk @106.9Mhz * x39 = 4.17Ghz, 8GB of 2600Mhz DDR3,.. Gigabyte GTX970 G1-Gaming @ 1550Mhz
Repair them.
thanks for the reply. Sorry i'm not familiar with this, so do i just download the 2017 one? like updating driver?
1 minute ago, kentcheung92 said:
yea I think 450W is enough to run this build. probably not the PSU problem.
Ah yeah lol in my Google search the original neoeco came up and I was like no. Yeah, it's what the other guy said.
M1 MacBook Air 256/8 | iPhone 13 pro
Nah you get ALL of them, very easy to think you only need the latest version as the webpage doesn't tell you otherwise.
VCredist 2008 is for apps that use 2008 libraries.but......so on and so forth... VisualBasic (apps builder) gets updated over time, but you download the older ones so the apps built upon those releases get updated. (AFAIK)
You should have all of them installed, not just the latest yearly ones.
When you install you could get a prompt saying already installed, and do you want to repair or cancel,
Repair them.
Repair them.
thanks! I went to check all of them in control panel and click repair for each of them (they're updated). See if this will solve the problem.
Is there any way I can check if my rams are working properly?
