Most Critical Component for Flight Simulators
Solved by Zyndo,
1 hour ago, Carl DaBeast said:Snip
not entirely sure which "flight simulators" you intend to play.... but that computer looks woefully inadequate. Sim's usually require/benefit from high amounts of RAM and strong CPU's with at least 4 physical cores. You should be looking at a larger budget if you're looking for a good time in your simulators (it will depend on the title though). This PC is even border-line for a decent GTA V experience, depending on what kind of framerates/resolution and settings you're willing to play at.
Also, you're massively overspending on your motherboard for features you cannot make use of.
