Hi,
I am uprgading my PC in the near future and want some advice on what I should do.
I have 2 builds in mind, which I'll list further down, but if you have any other builds, feel free to post them.
Requirements for recommendations:
1. WIFI, I do not have the ability to route ethernet cables to my PC.
2. That's it. (The WIFI can be in a seperate PCI-E card or just on the motherboard.
My builds:
Z270: https://uk.pcpartpicker.com/list/PJxXQV
X99: https://uk.pcpartpicker.com/list/tBPjxY
Thanks in advance.
https://linustechtips.com/topic/808336-new-build-need-help-deciding/
Image result for moon2smag
PCPartPicker UK doesn't necessarily have all parts consolidated on their website. I would recommend spending some time in each retailer and searching for the part(s) you want, in hopes you may find a listing that is different or cheaper.
For Wi-Fi:
- Regular: https://uk.pcpartpicker.com/product/Chh9TW/tp-link-wireless-network-card-tlwn881nd
- Wireless-AC: https://uk.pcpartpicker.com/product/tTdqqs/gigabyte-wireless-network-card-gcwb867di
