Storage outside of my PC Case
Solved by Mikensan,
13 hours ago, TenzoNakami said:I didn't quite get this: Can I access the data from somewhere else like a NAS could? Or I need a real NAS?
EDIT: Oops. Looks like the IcyDock only able to support up to 10TB? My RED is 4TB each, and my Purple is 6TB. In total I have 22TB?
Using the icydock is no different then plugging them into your motherboard. Or like using a USB external hard drive. It does nothing else but let Windows see your hard drives (passthrough).
It's 10TB disks, yours are 4TB so you're well below. Even when there are disks larger than 10TB easily available, likely a firmware update will fix that.
