Hey all,
I have 8 Gb g skill ripjaws ram in my pc now running at 1600mhz, i checked the ram specifications when I bought it and it says it can go upto 2133mhz
now my question is can I overclock just the ram without overclocking the cpu, my ram seems to be the bottle neck because when im playing games and alt tabbing to discord or my browser, it lags like hell. also i was checking frequency and stuff in the bios i can increase it upto 2400mhz and bclk only had 2 options 100:100 and 100:133 and auto, its set to auto but idk what the other 2 options mean.
I only have 8GB so is it worth it to overclock or buy 2 more sticks. its ddr3 btw my motherboard is asus z97-k
I think this is my memory stick:
https://www.newegg.com/Product/Product.aspx?Item=N82E16820231654&cm_re=gskill_ripjaws_ddr3_2133mhz-_-20-231-654-_-Product
https://linustechtips.com/topic/806185-dram-bclk-problem/
1 minute ago, Adgj533 said:
what do u mean? @TrigrH
what does XMP do?
srry im noob
it set the ram to its rated memory settings by loading a profile off the ram, it doesn't overclock the CPU.
https://linustechtips.com/topic/806185-dram-bclk-problem/#findComment-10128355
2 minutes ago, Adgj533 said:
ok i just did it and cpu z still shows my memory bandwidth max as 800mhz and it says PC3-12800
what does that mean? im also buying 2 more sticks of 4gb does it have to same brand/exact model of the current one i have? @TrigrH
it should say 1066.5 if it worked correctly the CPU-Z reading is HALF the rams speed,
https://linustechtips.com/topic/806185-dram-bclk-problem/#findComment-10128614
Just now, Adgj533 said:
ok @TrigrH it does show 1066.5 but how did you know that?
also why is it only showing half, is there a setting i have to enable?
also would u recommend increasing ram to 16 gb or keep 8?
DDR is double data rate so 2133/2 = 1066.5
https://linustechtips.com/topic/806185-dram-bclk-problem/#findComment-10128631
i need to know ur full system specs before i recommend anything.
https://linustechtips.com/topic/806185-dram-bclk-problem/#findComment-10128637
i have intel 4790k cpu asus z97-k motherboard gtx 970 gfx 8gb memory 1tb HD 1 sound card, 1 network card @TrigrH
do you have an SSD?
https://linustechtips.com/topic/806185-dram-bclk-problem/#findComment-10128647
no ssd at all
You have a good platform, i recommend this:
the same memory if you can afford it, otherwise 2 stick kit will do
250gb ssd
update bios to latest
install windows into the ssd.
https://linustechtips.com/topic/806185-dram-bclk-problem/#findComment-10128745
ty so much for all ur help, ill try to save up for that
meanwhile you can try playing in borderless windowed mode, you will suffer a small performance hit, I personally do it and don't care.
https://linustechtips.com/topic/806185-dram-bclk-problem/#findComment-10128844
