Hi all,
I've done some research on my own as far as possible build routes I'd like to explore, but figured I'd post here to see what you guys think.
I'm an audio engineer operating a recording studio, and the time has finally come where I need to replace my macbook Pro that I've used for recording and mixing for about 4 years.
(Yes all my software is cross-platform and allows me to switch between PC and Mac freely)
(may also serve as a Lightroom station so I would like to stay in the entry-level enthusiast grade graphics cards)
The current problem I am encountering is processing bottlenecks slowing down my mixing time, as the software crashes under light to moderate load with my current rig, a Macbook Pro running  2.8 GHz i7 Quad core w/ 16Gb 1600MHz DDR3 and 1TB solid state. I need to be able to work efficiently, without encountering bottlenecks.
My hard budget is $2500, but I'd love to get down to ~$2000, and I am located in the Southwestern U.S.
My goal is to migrate my permanent station to a desktop. The software I'm using is Pro Tools 12.4, which has relatively mild Graphics needs, but severe CPU and RAM requirements.
Would like to get 6-8 cores, with 32+GB of RAM, and 250GB of SSD or M.2 Storage. I have plenty of external storage, so hard storage won't need to be more than 500GB-1TB.
I will be utilizing a TV for the Main monitor, but would like the ability to expand to a second TV or LED Monitor, so 2 HDMI outputs would be desired.
I will require no additional peripherals, as I already have a nice Mech Keyboard and Gaming mouse I like, and it will be accessing the internet via Ethernet so no need for WiFi capability.
The software requirements dictate Windows 8, with a 64-bit architecture, as the software runs exclusively 64-bit programming.
For Reference here is a link to Avid's system requirements doc:
Avid System Requirements ( please refer to version 12.4 )
Thanks guys.
https://linustechtips.com/topic/805656-audio-engineers-build/
To be honest with you, you really don't need to spend $2500 if you don't want to, this more than meets your requirements
CPU: AMD - Ryzen 7 1700X 3.4GHz 8-Core Processor  ($329.99 @ Amazon)
CPU Cooler: Corsair - H100i v2 70.7 CFM Liquid CPU Cooler  ($109.89 @ OutletPC)
Motherboard: MSI - B350 GAMING PLUS ATX AM4 Motherboard  ($76.98 @ Newegg)
Memory: G.Skill - Ripjaws V Series 32GB (2 x 16GB) DDR4-3200 Memory  ($234.99 @ Newegg)
Storage: Samsung - 960 EVO 250GB M.2-2280 Solid State Drive  ($127.99 @ Amazon)
Storage: Western Digital - Caviar Blue 1TB 3.5" 7200RPM Internal Hard Drive  ($47.79 @ OutletPC)
Video Card: EVGA - GeForce GTX 1080 8GB FTW Gaming ACX 3.0 Video Card  ($599.89 @ B&H)
Case: NZXT - S340 Elite (Black) ATX Mid Tower Case  ($94.99 @ Newegg)
Power Supply: EVGA - SuperNOVA NEX 650W 80+ Gold Certified Fully-Modular ATX Power Supply  ($74.88 @ OutletPC)
Operating System: Microsoft - Windows 10 Home OEM 64-bit  ($89.89 @ OutletPC)
Total: $1787.28
Generated by PCPartPicker 2017-07-10 21:55 EDT-0400
https://linustechtips.com/topic/805656-audio-engineers-build/#findComment-10122810
Total: $1787.28
Good, except regular 1700 is good enough and he said he would
so 1050Ti or 1060 not 1080 :P
-----> Official Unofficial Favorite Keyswitch Type Survey <-----
 OWNER OF THE FASTEST INTEL iGPU ON LTT UNIGINE SUPERPOSITION [lol]
GAMING RIG "SNOWBLIND"
CPU i5-13600k | COOLING Corsair H150i Elite Capellix 360mm (White) | MOTHERBOARD Gigabyte Z690 Aero G DDR4 | GPU Gigabyte RTX 3070 Vision OC (White) | RAM  16GB Corsair Vengeance Pro RGB (White)SSD Samsung 980 Pro 1TB | PSU ASUS STRIX 850W (White)CASE  Phanteks G360a (White) | HEADPHONES  Beyerdynamic DT990 Pro | KEYBOARD Zoom75 (KTT Strawberry w/ GMK British Racing Green keycaps) | MOUSE  Cooler Master MM711 (White) MONITOR HP X32 1440p 165hz IPS
WORK RIG "OVERPRICED BRICK"
Mac Studio (M2 Ultra / 128GB / 1TB) | HEADPHONES  AirPods Pro 2 | KEYBOARD Logitech MX Mechanical Mini | MOUSE  Logitech MX Master 3S MONITOR 2x Dell 4K 32"
SECONDARY RIG "ALCATRAZ"
CPU i7-4770K OC @ 4.3GHz | COOLING Cryorig M9i (review| MOTHERBOARD ASUS Z87-PROGPU Gigabyte 1650 Super Windforce OC | RAM  16GB Crucial Ballistix Sport DDR3 1600 MHzSSD Samsung 860 Evo 512GB | HDD Toshiba 3TB 7200RPMPSU EVGA SuperNOVA NEX 750WCASE  NZXT H230 | HEADPHONES  Sony WH-1000XM3  | KEYBOARD Corsair STRAFE - Cherry MX Brown | MOUSE  Logitech G602 MONITOR LG 34UM58-P 34" Ultrawide
HOLA NIGHT THEMERS
GET YOUR ASS ON NIGHT THEME
OTHER TECH I OWN:
MacBook Pro 16" [M1 Pro/32GB/1TB] | 2022 Volkswagen GTI | iPhone 14 Pro | Sony a6000 | Apple Watch Series 8 45mm | 2018 MBP 15" | Lenovo Flex 3 [i7-5500U, HD5500 (fastest on the forum), 8GB RAM, 256GB Samsung 840 Evo] | PS5, Xbox One & Nintendo Switch [Home Theater setup] | DJI Phantom 3 Standard | AirPods 2 | Jaybird Freedom (two pairs) & X2 [long story, PM if you want to know why I have 3 pairs of Jaybirds]
https://linustechtips.com/topic/805656-audio-engineers-build/#findComment-10122848
Total: $1787.28
Or even a 1070 or 1060 could work if you dont need a ton of graphics performance.
https://linustechtips.com/topic/805656-audio-engineers-build/#findComment-10122849
Only reason I gave him a 1080, is if I gave him like a 1050 ti or 1060 it would be so far under his budget xD
https://linustechtips.com/topic/805656-audio-engineers-build/#findComment-10122854
TFW you need more expensive components lolllllllllll
HOLA NIGHT THEMERS
OTHER TECH I OWN:
https://linustechtips.com/topic/805656-audio-engineers-build/#findComment-10122858
Considering a 1060 is basically a 980, I would say thats plenty powerful. I'd also drop the CPU to a 1600 with that cooling you'll easily hit 4.0Ghz and no point in overkilling. Maybe even go up to a 512gb SSD won't have anythin to worry about there. Otherwise first build looks really good.
Redstone:
i7-4770 / Z97 / GTX 980 / Corsair 16GB  / H90 / 400C / Antec EDGE / Neutron GTX240 / Intel 240Gb / WD 2TB / BenQ XL24
Obsidian:
MSI GE60 2PE i7-4700HQ / 860M / 12GB / WE 1TB / m.Sata 256gb/Elagto USB HD Capture Card
Razer Deathadder Chroma / Razer Blackwidow TE Chroma / Kingston Cloud2's / Sennheiser 429 / Logitech Z333
https://linustechtips.com/topic/805656-audio-engineers-build/#findComment-10122940
Nah, stick with the 8 core because why not, it's WAY under his budget anyway
https://linustechtips.com/topic/805656-audio-engineers-build/#findComment-10122952
TBH I would probably lean towards the higher overclocked cpu and stick to a 1050TI. Better Computational power off the CPU is key. When I said this program is a cpu hog, Avid recommends Xeon 2660v3 10-cores for it's top performance tier users (96-256 audio channels @ 32-bit/196KHz).
But this definitely makes me want to lean towards the Ryzen lineup more than I already was, since that comparable system is more expensive on intel chipset.
One thing I wouldn't mind is a Mobo with a few more usb 3.0/3.1 inputs and higher Ram max, but I can probably source that myself and this has given me a really good jumping off point
Thanks guys
https://linustechtips.com/topic/805656-audio-engineers-build/#findComment-10123635
Reconfigured some stuff for a forgotten factor; Noise level. Swapped the case for the Fractal R5, went for a fanless PSU from SeaSonic, and upped the USB count with an Asus B350 Prime Plus Mobo.
CPU Cooler: Noctua - NH-U9B SE2 37.9 CFM CPU Cooler  ($61.40 @ Amazon)
Thermal Compound: Arctic Silver - 5 High-Density Polysynthetic Silver 3.5g Thermal Paste  ($5.84 @ OutletPC)
Motherboard: Asus - PRIME B350-PLUS ATX AM4 Motherboard  ($93.88 @ OutletPC)
Storage: Western Digital - Caviar Blue 1TB 3.5" 7200RPM Internal Hard Drive  ($39.99 @ Amazon)
Video Card: Asus - GeForce GTX 1060 6GB 6GB Strix Video Card  ($379.89 @ B&H)
Case: Fractal Design - Define R5 Blackout Edition ATX Mid Tower Case  ($89.99 @ SuperBiiz)
Power Supply: SeaSonic - 520W 80+ Platinum Certified Fully-Modular Fanless ATX Power Supply  ($129.99 @ NCIX US)
Total: $1583.84
Generated by PCPartPicker 2017-07-11 04:21 EDT-0400
thoughts?
https://linustechtips.com/topic/805656-audio-engineers-build/#findComment-10124212
Total: $1583.84
thoughts?
That would work, but I would get a different PSU
https://linustechtips.com/topic/805656-audio-engineers-build/#findComment-10125364
For a similar price, you could just get a high-wattage PSU with a fan that turns off when the rig isn't past a certain point.
HOLA NIGHT THEMERS
OTHER TECH I OWN:
https://linustechtips.com/topic/805656-audio-engineers-build/#findComment-10128252
