Hey there, just wanted to post my first mining rig up and see what everyone thinks. its still a work in progress, no cables managed, fans just sitting on their sides in the chassis. good old DIY stuff :) stuck between actually finding graphics cards and also affording them :P but this startup rig put together thanks to my old buddy Craig with this list hes got. Mobo and CPU are total overkill for a mining rig, but im also learning linux so it gives me all the headroom i could want to tinker when im doing that with it. will eventually replace with a G4400 most likely at some point once i have 6 gpus total.
Current Specs-Cost.        All prices in Canadian Ruppies
Asus max iv extreme (v1.0) w/2600k @4.4GHZ-320$
GTX 1060 6gb EVGA SSC-300$  -80% power -100 clock +850mem 23.3~ mh/s
GTX 1070 Asus Strix OC-500$(thing is a beast) -80% power -100 clock +650mem 30.3~mh/s
about twelve 120mm fans that ive collected over the last while. -50$
750 watt EVGA P2 platinum PSU-110$ on sale long time ago. finally get to use it
Old 3u, 21 indeep server chassis that i got for 35 bucks! Prolly the best deal out of anything.
15dollar Potato CPU cooler since all i had was a 212 evo and it was too tall. considering pulling a linus on it with a hack saw. it couldnt perform worth than the potato cooler :P
Running Claymore Etherium Dual miner on Single currency mode (eth only) windows 10 that came with mobo....for now
6Pack Riser cards - 60 bucks still awaiting them since they are coming from china
Total cost around 1390 CDN.
The market has been very volatile the last couple days. mostly down, but still all over. as of posting its running at 53 - 54 mh/s, netting me around 160 a month after power costs. Thx BC and good old hydro power. im not worry if the market totally tanks, for now its still got a long way to go before its a loss for me. Also like i said im learning linux and just generally like having fun tinkering with computers. i may stick a harddrive in it too for some extra storage off my main rig. When the Riser arrive il be setting them up so the GPUs will be mounted along the front portion of the chassis, with push pull fans (properly) mounted around them. Temps are already sitting at 60C on both GPUs with gpu fans around 30 %. Fun feature on the asus card is it has 2x4pin fan headers to let you control case fans with the GPU fan profile. plugged my fan hub in and boom, gpu is controlling the case fans. super cool feature.
any who, here are some pics, let me know what you think, any tips and suggestions appreciated :)
https://linustechtips.com/topic/805545-my-first-mining-rig/
The thing that gives me the most happiness: You only used 2 cards! Hooray! (I don't like it when people buy up 8-10 cards to slap in a box and run 24/7 mining, vs using them for gaming like they were designed for)
And I hope it lasts a long time and you can get a good ROI. B|
Gaming PC NAS Laptop Workstation
CPU: i5 12600KF 6P+4E Ryzen 7 3700X M4 SoC 4P+6E Xeon X5690 6c12t
Cooler: Noctua NH-D15S Wraith Stealth w/NF-A9 Passive Apple CPU Cooler
Motherboard: ASRock Z690 ITX/ax ASUS Pro B550M-C/CSM Apple J713AP Mac-F221BEC8 (Mac Pro 5,1)
RAM: 2x16GB 3600Mhz DDR4 2x16GB 2400MHz DDR4 24GB Micron LPDDR5 4x8GB 1333MHz ECC DDR3
GPU: Sapphire Pulse Radeon 9060 XT 16GB Radeon WX2100 M4 SoC 10C Radeon RX 5700
Storage: 1TB MP34 + 2TB P41 500GB SSD + 2x4TB IronWolf Pro in ZFS Mirror Apple AP0512Z 1TB Crucial MX500
ODD: LG WH14NS40 None LG GP65NB60 USB DVD Writer Don't know
PSU: EVGA 850W GM Silverstone SST-TX300 53.8Wh LiPo Battery Delta DPS-980BB
Case: Silverstone Sugo 14 Dell Inspiron 530S Mac16,12 chassis (13" MBA) 2009-2012 Mac Pro "Cheese Grater"
OS: Gentoo Linux TrueNAS Scale macOS 26 Tahoe Fedora Linux
Mouse: EVGA X17
Keyboard: Corsair K55 RGB
Mobile/Work Devices: 14" M5P MacBook Pro (work) - iPhone 17 Pro - Apple Watch S11
Other Misc Devices: iPod Video (Gen 5.5E, iFlash Solo w/128GB SD Card, Rockbox), Nintendo Switch
Vehicles: 2002 Ford F150, 2003 Harley-Davidson Sportster 1200, 2022 Kawasaki KLR650, 1994 DR350SE
https://linustechtips.com/topic/805545-my-first-mining-rig/#findComment-10121463
Thank you! However if i had another 2k in my pocket, there would be 4 1070s of any type coming to me off ebay right now :P im not that noble. I actually got the 170 for my main rig to replace two 960s. but the 960s dont mine well and im stuck at 1080p anyways so screw it, let the 1070 buy my monitor :)
https://linustechtips.com/topic/805545-my-first-mining-rig/#findComment-10121472
nice rig,
I was just wandering why mining? you build it for the knowledge and tinkering ich,, or for the possible coins you will get from it?
It looks like the ROI would be hard to hit...
You didnt ask me but, if I were you and had 2k to invest in cryptos, I would buy coins directly.
Good Luck.
Looking around,
bla bla bla this, meh that!
https://linustechtips.com/topic/805545-my-first-mining-rig/#findComment-10121611
1 hour ago, Andmanpro said:
GTX 1060 6gb EVGA -80% power -100 clock +850mem 23.3~ mh/s
GTX 1070 Asus Strix -80% power -100 clock +650mem 30.3~mh/s
So, I should overclock my 1080 differently.
How did you come to those memory clocks?
CPU — AMD Ryzen 7800X3D
GPU — AMD RX 7900 XTX - XFX Speedster Merc 310 Black Edition - 24GB GDDR6
Monitor — Acer Predator XB271HU - 2560x1440 165Hz IPS 4ms
CPU Cooler — Noctua NH-D15
Motherboard — Gigabyte B650 GAMING X AX V2
Memory — 32GB G.Skill Flare X5 - 6000mHz CL32
Storage — WD Black - 2TB HDD
        — Seagate SkyHawk - 2TB HDD
        — Samsung 850 EVO - 250GB SSD
        — WD Blue - 500GB M.2 SSD
        — Samsung 990 PRO w/HS - 4TB M.2 SSD
Case — Fractal Design Define R6 TG
PSU — EVGA SuperNOVA G3 - 850W 80+ Gold
Case Fans — 2(120mm) Noctua NF-F12 PWM - exhaust
          — 3(140mm) Noctua NF-A14 PWM - intake
Keyboard — Max Keyboard TKL Blackbird - Cherry MX blue switches - Red Backlighting
Mouse — Logitech G PRO X
Headphones — Sennheiser HD600
Extras — Glorious PC Gaming Race - Mouse Wrist Rest
       — Glorious PC Gaming Race - XXL Extended Mouse Pad - 36" x 18"
       — Max Keyboard Flacon-20 keypad - Cherry MX blue switches
https://linustechtips.com/topic/805545-my-first-mining-rig/#findComment-10122036
  • 3 weeks later...
On 7/10/2017 at 3:13 PM, GamingMemeKing said:
-80% power.
Does this mean you are using only 20% TDP or are you at 80%?
yes sorry, power is AT 80%
Trial and error. Highest mem clock i could get stable with lowest power draw
https://linustechtips.com/topic/805545-my-first-mining-rig/#findComment-10215176
so small update. riser arrived and i have the 1070, 1060 and two 960s in the rig. unfortunatly due to the controller on the Max 4, only 3 are recognized. looking into a sabertooth off ebay and sell off the max 4, will be able to get 6 running no problem on it.
https://linustechtips.com/topic/805545-my-first-mining-rig/#findComment-10215180
