Hi I'm still using my PC from 2014 and I think its time for an upgrade.
Specs are: -I7 4770 (non K) - 16 GB RAM - -Some crappy Micro-ATX Motherboard -GTX 770 and a 1TB HDD
My Plan is to keep the CPU and upgrade the other Parts for an ATX Motherboard, new 16 GB RAM, a GTX 1070/1080, a SSD and a new case for the new motherboard.
My question now is: Could the i7 4770 be a bottleneck for the new graphics card or is it still fine.
I don't think that the CPU needs to be upgraded since its never working over 60-70% on high load.
I'm a casual gamer and sometimes I work a bit on editing.
THX for the help :)
https://linustechtips.com/topic/805299-possible-cpu-bottleneck/
No, it's fine. The word "bottleneck" is thrown a lot with no real meaning. I wouldn't worry about it.
'Fanboyism is stupid' - someone on this forum.
Be nice to each other boys and girls. And don't cheap out on a power supply.
CPU: Intel Core i7 4790K - 4.5 GHz | Motherboard: ASUS MAXIMUS VII HERO | RAM: 32GB Corsair Vengeance Pro DDR3 | SSD: Samsung 850 EVO - 500GB | GPU: MSI GTX 980 Ti Gaming 6GB | PSU: EVGA SuperNOVA 650 G2 | Case: NZXT Phantom 530 | Cooling: CRYORIG R1 Ultimate | Monitor: ASUS ROG Swift PG279Q | Peripherals: Corsair Vengeance K70 and Razer DeathAdder
https://linustechtips.com/topic/805299-possible-cpu-bottleneck/#findComment-10118930
If you keep the CPU then there's no point in upgrading, unless you just want more ports, PCIe slots, WiFi etc.
Desktop benching:
https://linustechtips.com/topic/805299-possible-cpu-bottleneck/#findComment-10118939
new ram doesn't make a difference unless it looks different.
new mobo only helps with more connectors, doesn't impact performance.
rest is an ok upgrade, the i7 is still relevant
GUITAR BUILD LOG FROM SCRATCH OUT OF APPLEWOOD
- Ryzen Build -
R5 3600 | MSI X470 Gaming Plus MAX | 16GB CL16 3200MHz Corsair LPX | Dark Rock 4
MSI 2060 Super Gaming X
1TB Intel 660p | 250GB Kingston A2000 | 1TB Seagate Barracuda | 2TB WD Blue
be quiet! Silent Base 601 | be quiet! Straight Power 550W CM
2x Dell UP2516D
- First System (Retired) -
Intel Xeon 1231v3 | 16GB Crucial Ballistix Sport Dual Channel | Gigabyte H97 D3H | Gigabyte GTX 970 Gaming G1 | 525 GB Crucial MX 300 | 1 TB + 2 TB Seagate HDD
be quiet! 500W Straight Power E10 CM | be quiet! Silent Base 800 with stock fans | be quiet! Dark Rock Advanced C1 | 2x Dell UP2516D
Reviews: be quiet! Silent Base 800 | MSI GTX 950 OC
https://linustechtips.com/topic/805299-possible-cpu-bottleneck/#findComment-10119046
Yeah I want more ports and since it is a really cheap one from MSI it doesn't live up to my expectations anymore
https://linustechtips.com/topic/805299-possible-cpu-bottleneck/#findComment-10119050
I thought about keeping the RAM I'm not quite sure yet but thx for your help
https://linustechtips.com/topic/805299-possible-cpu-bottleneck/#findComment-10119053
THX for the help :)
http://thebottlenecker.com/ try this website?
https://linustechtips.com/topic/805299-possible-cpu-bottleneck/#findComment-10119061
No point in buying different RAM unless you opt for faster modules.
Use the quote function when answering! Mark people directly if you want an answer from them!
https://linustechtips.com/topic/805299-possible-cpu-bottleneck/#findComment-10119249
