Hey everyone.
I will be moving about 200km into the middle of nowhere for work purposes. My wifi will come from a satellite dish that will be connected to my trailer. the problem is there will be 2 more trailers (co-workers) about 200 feet from my trailer (so we will be in triangle formation). I am wondering if i would be able to get my wifi signalto the other two trailers (through range extenders, outdoor wifi router). Any ideas would be great thx
https://linustechtips.com/topic/805193-outdoor-wifi/
Check out Ubiquiti Networks they do a whole heap of this sort of stuff.
Some of their Unifi stuff is "weather proof" and they also have some out door network stuff called 'AirFibre'.
It can get a bit expensive though...
Hopefully this helps!
**edit**
Might be cheaper to run a small network switch and run outdoor rated cat 6 ethernet cables?
Asus Z77 Sabertooth, Intel Core i5 3570k 4.2 GHz, EVGA GTX 780, Corsair Vengeance 16Gb ,
Samsung EVO 250&500Gb, Western Digital Black 2TB,  Corsair RM 750
Custom Water Loop
CPU Block Koolance 380iGPU Block EKWB Clean CSQPump Laing DDC w/ EKWB X-RES 100Radiatiors NexXxoS Monsta 240 & Swiftech 240x35Tubing PrimoChill Primoflex Advanced LRT Elegant White 3/8" ID 5/8" ODFittings White Monsoon Free Centre Compression Fittings 3/8" ID 5/8" ODFans6x Noctua NF-F12 w/Noctua LNA Adaptors
https://linustechtips.com/topic/805193-outdoor-wifi/#findComment-10117817
I'm no expert in the external WiFi field but i think that is also a point to point solution.
Custom Water Loop
https://linustechtips.com/topic/805193-outdoor-wifi/#findComment-10118156
