so i decided to give my little brother my old gaming pc that i havent used in a few months, i put a new hard drive in it cause the old one is in my current pc since im too lazy to transfer it. the pc boots and goes to bios and everything works, it recognizes the boot device but i CANT GET IT TO START. it just says "reboot and select proper boot device" ive saved and restarted a million times. please help before i blow my brain out
specs: asrock z97 anniversary edition
1tb WD blue
i5-4690
16gb ddr3 hyper x fury
evga 600b
https://linustechtips.com/topic/804774-please-help/
Make a bootable windows USB key, and boot from that then install windows on the HD
CPU: Intel Core i7 8700k CPU Cooler: Corsair Hydro Series H100i Mobo:  Memory: G.Skill Ripjaws X 32GB 2133 Storage #1: 1TB 850 EVO SSD Storage #2: Western Digital Black 2TB Storage #3: Western Digital Green 4TB GPU: Gigabyte 980 Ti G1 Case: Mastercase5 PSU: EVGA 750 W G2 80+Gold Keyboard: Corsair K70 RGB Cherry MX Brown Mouse: Razer Deathadder Elite Monitor: LG 34UM94 Headset: Bose
Phone: Samsung Galaxy S9
https://linustechtips.com/topic/804774-please-help/#findComment-10113528
1tb WD blue
i5-4690
evga 600b
Does the hard drive have Windows on it?
M1 MacBook Air 256/8 | iPhone 13 pro
https://linustechtips.com/topic/804774-please-help/#findComment-10113529
Just now, caseyf said:
it should give me the free trial by default right? it did that with my new build i did only months ago
When you buy a hard drive NOTHING comes on it. So you have to make an installer and install it.
https://linustechtips.com/topic/804774-please-help/#findComment-10113548
how do i do it? Also is there a way i get the free version? i really cant shell out over 100$ for windows 10
No *legal* way to do that sorry. Download the windows 10 installation media creator here, a simple Google search will find it, and it should explain itself
https://linustechtips.com/topic/804774-please-help/#findComment-10113565
Get a USB, download their tool to make it boot able (just follow the instructions).
https://www.microsoft.com/en-au/software-download/windows10
Please quote our replys so we get a notification and can reply easily. Never cheap out on a PSU, or I will come to watch the fireworks.
PSU Tier List
My specs
PC:
CPU: Intel Core i5-6600K @4.8GHz
CPU Cooler: Noctua NH-U14S
Motherboard:  ASUS Maximus VIII Hero
GPU: Zotac AMP Extreme 1070 @ 2114Mhz
Memory: Corsair Vengeance LPX 16GB (2 x 8GB) DDR4-2400
Storage: Samsung 850 EVO-Series 500GB
Storage: Western Digital Caviar Blue 1TB
Case: Cooler Master MasterCase Pro 5
Power Supply: EVGA 750W G2
Peripherals
Keyboard: Corsair K70 LUX Browns
Mouse: Logitech G502
Headphones: Kingston HyperX Cloud Revolver
Monitor: U2713M @ 75Hz
https://linustechtips.com/topic/804774-please-help/#findComment-10113567
so theres ways to get it free? that isnt a scam or will rat my brothers PC?
No legal ways, and I don't endorse piracy so no there isn't, however the trial is not very limiting at all and it should work until you can buy a product key.
https://linustechtips.com/topic/804774-please-help/#findComment-10113571
do i just download the thing and leave it on the usb, or should i set it up on my current pc then put it on my brothers?
https://linustechtips.com/topic/804774-please-help/#findComment-10113575
There is an option when booting with it to use without a key, it will still work fine (Just you *Should* later buy a key, not that that matters).
PSU Tier List
My specs
PC:
Peripherals
https://linustechtips.com/topic/804774-please-help/#findComment-10113590
