ANTEC VP650P V2 650W POWER SUPPLY
is this power supply any good. It is the only one I can find in my budget at the moment and antec is a nice brand I think...
CPU: Fx 8350 | CPU Cooler: Coolermaster Hyper 212 Evo Now  AMD STOCK CPU COOLER | Motherboard: Gigabyte GA-970A-DS3 (rev 1.1)   NOW MSI 990FXA-GD80 | Ram: Corsair Vengence 8GB DDR3 Motherboard detects 7gb for some weird reason | Graphics Card: SAPPHIRE HD 7870 GHz Edition 2GB GDDR5 |  HDD: 1 TB samsung
Case: CM elite 310 | Monitor: Aoc e2050S
OS: Windows 8 Professional 64 Bit NOW  Wndows 10 Professional 64 Bit
 Power Supply: Cooler Master Thunder 500W NOW GX 650W v2
https://linustechtips.com/topic/804047-need-help-selecting-a-power-supply/
Just now, deXxterlab97 said:
Antec VP is not good. You need to tell us more than just throwing a PSU at us
Like where do you live?
How much can you spend?
What's it's gonna power?
Do you need extra features?
Like where do you live? India, new delhi.
How much can you spend? 6,500 rs or  100$
What's it's gonna power? CPU: Fx 8350 | CPU Cooler:  probably an h100i  | Motherboard:  MSI 990FXA-GD80  | Ram: Corsair Vengence 8GB DDR3 | Graphics Card: SAPPHIRE HD 7870 GHz Edition 2GB GDDR5 |  HDD: 1 TB samsung  Case : still thinking. | 1 optical drive and 4,5 fans.
Do you need extra features?  Do not know what you mean by extra features.
Thanks for your help appreciated
Just now, DisguisedDemise said:
EVGA 650W G2? i have good experience with this,
Cant find evga here anywhere sadly.
http://www.amazon.in/Corsair-CX500-80-Plus-Power-Supply/dp/B009RMP2VE/ref=sr_1_1?ie=UTF8&qid=1499441077&sr=8-1&keywords=corsair+cx
A bit better than Basic VP you chose.
Oh wow, any seasonic or maybe bequiet supplies there ? anything with high effecience and 650+ watts should be fine. just double check it against the many PSU tierlists out there :P
Also do you have any other store than Amazon for me to look at?
Would a 500w be enough I used cooler master thunder 500 w before it constantly died on me.,,
I was thinking to go for 600w maybe?
flipkart, snapdeal, primeabgb all are .com
what about this one http://www.amazon.in/Corsair-CP-9020098-UK-VS650-Power-Supply/dp/B00PGUSEBG/ref=sr_1_9?ie=UTF8&qid=1499445008&sr=8-9&keywords=Corsair+CX
