    Hey everyone, this is probably a really stupid question, but I need to know if this cable will work to connect my graphics card to my power supply. I'm building my first computer, starting with a used system that I picked up for $50 on Ebay. The power supply, unsurprisingly, didn't come with any extra cables, and I'm trying to find a cable to connect my new graphics card with. This cable appears to have one pin different (top middle on the PSU connector). Will it still work? If not, can someone link to one that will? Thanks in advance!
Cable: https://www.amazon.com/JacobsParts-Express-6-pin-PCI-e-Video/dp/B00OSLGBIC/ref=sr_1_3?ie=UTF8&qid=1499395082&sr=8-3&keywords=pcie+power+cable
PSU: http://store.antec.com/basiqseries/bp550-plus.html#
Graphics Card: https://www.newegg.com/Product/Product.aspx?item=N82E16814125906
https://linustechtips.com/topic/803810-pcie-power-connector/
I know but I need to know what wattage of a PSU you need
Im mostly on discord now and you can find me on my profile
My Build: Xeon 2630L V, RX 560 2gb, 8gb ddr4 1866, EVGA 450BV
My Laptop #1: i3-5020U, 8gb of DDR3, Intel HD 5500
https://linustechtips.com/topic/803810-pcie-power-connector/#findComment-10103780
I'm using this PSU: http://store.antec.com/basiqseries/bp550-plus.html#
The CPU is an Athelon II, thinking about switching platforms to something like Ryzen down the line though.
https://linustechtips.com/topic/803810-pcie-power-connector/#findComment-10103786
and your fine for your SPU you dont need an extension at all
https://linustechtips.com/topic/803810-pcie-power-connector/#findComment-10103788
It will bottle neck the shit out of the 1060
https://linustechtips.com/topic/803810-pcie-power-connector/#findComment-10103789
Yes, I'm aware. Like I said, just trying to get this for now so I can upgrade CPU later.
So that cable will work?
https://linustechtips.com/topic/803810-pcie-power-connector/#findComment-10103795
Yep
https://linustechtips.com/topic/803810-pcie-power-connector/#findComment-10103805
You should not use any cables that did not come with your power supply unless you know the pinout on the PSU.
Otherwise you might fry your GPU and possibly your other computer hardware.
Contact the manufacturer and ask them to send you the proper cables.
This is not a cable extension. It is a PCIe 6 to 6 pin.
Extensions have a male and female end, and they DO NOT plug into the PSU, they plug into the PSU cables.
https://linustechtips.com/topic/803810-pcie-power-connector/#findComment-10103852
I don't understand why you need an adapter in the first place. The website of the PSU clearly shows that it has PCIe 6+2 and 6 pin available out of the box.
Desktop benching:
https://linustechtips.com/topic/803810-pcie-power-connector/#findComment-10103933
I got the PC used, I only have two of them and they're both in use.
https://linustechtips.com/topic/803810-pcie-power-connector/#findComment-10103936
Only have 2 what? 2 PCIe power cables? It originally came with 2, so you didn't lose any of them. In this case, using an adapter is risky since it might pull too much power from the PSU.
Desktop benching:
https://linustechtips.com/topic/803810-pcie-power-connector/#findComment-10103949
Not to mention that it doesn't have a socket for mini PCIe. You will need a molex to 6 pin adapter.
Desktop benching:
https://linustechtips.com/topic/803810-pcie-power-connector/#findComment-10103953
No - I have 2 SATA cables. No PCIe cables. I'm not sure how the PCIe cables got lost along the way, but I don't have them. The whole PC was only $50 anyway so I didn't question it.
https://linustechtips.com/topic/803810-pcie-power-connector/#findComment-10103956
Can you give me a list of all the cables that I would need?
The card needs 1 6pin. However, you will need cables that are both male connectors (both ends insert to something). I think it's called something like "PSU PCIe to PCIe 6pin", something like that. Just make sure both ends are used to plug in to something, not being plugged in, like adapters.
Desktop benching:
https://linustechtips.com/topic/803810-pcie-power-connector/#findComment-10103979
Okay
https://linustechtips.com/topic/803810-pcie-power-connector/#findComment-10103984
9 minutes ago, MrSaltyCactus said:
Oh sweet! How much did they charge you?
Approximately $15.00 including shipping and it got to me within two days of ordering it - I was really impressed and the quality is just as good, if not better, than the OEM cables that came with my PSU.
The Potato Box:
AMD 5950X
EVGA K|NGP|N 3090
128GB 3600 CL16 RAM
The Scrapyard Warrior:
AMD 3950x
EVGA FTW3 2080Ti
64GB 3200 CL16 RAM
https://linustechtips.com/topic/803810-pcie-power-connector/#findComment-10104141
