OK, So Im trying to get a PC up and running, It has a Pentium e5400, 3GB ram, 250gb storage, running on an Asus P5LD2-VM. So it runs,Got windows 7 installed ect. But there's 1 problem that seems to consist even when trying windows 10, 7 and xp, Which makes it horribly slow. In the bios it says the CPU is running at 1.35 GHz, In the properties of windows 7, 10 and xp it says "Pentium e5400 2.7ghz 1.35ghz"
I initially thought the FSB was too slow, (CPU requires 800) But then I looked at the specs for the motherboard and it said it supported 1066/800/533 MHz, What confused me more is that it was running at 900mhz, With the otpion to change it greyed out.
I know The wordings a bit weird, But please excuse me Im quite confused at this.
https://linustechtips.com/topic/801294-fsbcpumotherboard-issue/
maybe you need to scroll a bit lower to see the option? Otherwise, try find the bus speed (not fsb) and set that higher (default should be 200). Also, the multiplier should be 13.5.
Desktop benching:
https://linustechtips.com/topic/801294-fsbcpumotherboard-issue/#findComment-10076984
Nope. Nothing To do with Bus speed, Nothing can really be changed to do with clock speeds.
https://linustechtips.com/topic/801294-fsbcpumotherboard-issue/#findComment-10077013
MrIceCremeLollipop
These 945 boards running 2 Pentiums, lol, a pentium 4 chipset, so max 1066 for core 2,but you run a newer Pentium D on it, E6400 is a Core 2, you mixed them up, you get max 800 on these newer E6400 Pentiums, budget release next to the budget X 9550, mean for intel 4 chipsets, not the 945 or 965! Budget CPU's next to the i7 lineup, to compete with Athlon.
https://linustechtips.com/topic/801294-fsbcpumotherboard-issue/#findComment-10077030
those CPU don't always run on full tilt. On normal desktop use they throttle down,
You could run a tool like cpu - z or speccy, then take a look at the cpu frequency on idle, then start something more demanding and keep the frequency in view. It will go up then.
Main System:
Anghammarad : Asrock Taichi x570, AMD Ryzen 7 5800X @4900 MHz. 32 GB DDR4 3600, some NVME SSDs, Gainward Phoenix RTX 3070TI
System 2 "Igluna" AsRock Fatal1ty Z77 Pro, Core I5 3570k @4300, 16 GB Ram DDR3 2133, some SSD, and a 2 TB HDD each, Gainward Phantom 760GTX.
System 3 "Inskah" AsRock Fatal1ty Z77 Pro, Core I5 3570k @4300, 16 GB Ram DDR3 2133, some SSD, and a 2 TB HDD each, Gainward Phantom 760GTX.
On the Road: Acer Aspire 5 Model A515-51G-54FD, Intel Core i5 7200U, 8 GB DDR4 Ram, 120 GB SSD, 1 TB SSD, Intel CPU GFX and Nvidia MX 150, Full HD IPS display
Media System "Vio": Aorus Elite AX V2, Ryzen 7 5700X, 64 GB Ram DDR4 3200 Mushkin, 1 275 GB Crucial MX SSD, 1 tb Crucial MX500 SSD. IBM 5015 Megaraid, 4 Seagate Ironwolf 4TB HDD in raid 5, 4 WD RED 4 tb in another Raid 5, Gainward Phoenix GTX 1060
(Abit Fatal1ty FP9 IN SLI, C2Duo E8400, 6 GB Ram DDR2 800, far too less diskspace, Gainward Phantom 560 GTX broken need fixing)
Nostalgia: Amiga 1200, Tower Build, CPU/FPU/MMU 68EC020, 68030, 68882 @50 Mhz, 10 MByte ram (2 MB Chip, 8 MB Fast), Fast SCSI II, 2 CDRoms, 2 1 GB SCSI II IBM Harddrives, 512 MB Quantum Lightning HDD, self soldered Sync changer to attach VGA displays, WLAN
https://linustechtips.com/topic/801294-fsbcpumotherboard-issue/#findComment-10077038
Like @LucasRem, I also suspect the chipset support problem. Socket 775 is a weird one. Old mobos don't support newer CPUs running at their full speed, but you can still fit them in and run slowly.
Desktop benching:
https://linustechtips.com/topic/801294-fsbcpumotherboard-issue/#findComment-10077040
2 minutes ago, LucasRem said:
MrIceCremeLollipop
Not a clue what you mean lol.
https://linustechtips.com/topic/801294-fsbcpumotherboard-issue/#findComment-10077052
Jurrunio, it gets supported, only on 800 FSB max, not on 1600 or 1066 as Core 2 CPU's can do.
PC building is not that hard, stay in the right era! not mixing up Pentium 4 and Pentium D CPU's They are compatible, that 775 socket was good, but when you mix gens, it's getting weirder and weirder....
https://linustechtips.com/topic/801294-fsbcpumotherboard-issue/#findComment-10077055
